Originally Posted by MrVizio
Yeah, I know. CRT days seemed so simple.
Personally, I'm using THX with 80 contrast, 54 Brightness, and Warm 1 (sometimes Normal). This is with 2.1 patch.
If you tend to use your set in a pretty dim or all dark environment, then you might not want to apply 2.1. But I usually have a bit of light present.
I, however, really like it. Plus, it seems that pro calibrators apply it before they go to work, so it's obviously beneficial in that regard.
A disk can def help because your adjusting things specifically to your set and your environment. Plus you can use it on other sets in the house, as well as future sets.
I'm proud owner of this beautiful 65GT30 and would like to seek some advice, i know there are lot of pages of info in here.. but do i need to run d-nice slides to break in or just apply 2.1 patch and start watching TV
Please advice, maybe I already asked this in the other thread....
TIA
I ran the slides and the Dnice settings. I have not installed the 2.1 patch, as I have a room that can be darkened. I think it looks great just the way it is. I like THX for BD and the DaveO settings (w/o the 2.1) for satellite
