Originally Posted by
B|G1
Hello.
I play media on my TV with USB and Philips mediaconnect.
What settings to turn on so that my Onkyo TX-NR709 receiver can receive audio from the TV? TV is connected to main out ARC. And my TV (Philips 55PFL7606 have ARC (audio return channel)).
Hi B|G1, did your tv detected the HDMI input connection?
For ARC to work enable the receiver HDMI Control and ARC (see page 17) . On the Tv enable HDMI-CEC feature call EasyLink and set the speaker output. But make sure that EasyLink has detected the HDMI (receiver) connection.
B|G1
The HDTV PVR decoder is connected to HDMI 7 (TV/CD)
The TV is connected to main output.
Why should I change to TV/CD when I want sound coming from the TV (main output) and not the decoder??
Reasons in OM:
Do not assign an HDMI IN to the TV/CD selector while "HDMI Control (RIHD)" is set to "ON" (-> page 58), otherwise appropriate CEC (Consumer Electronics Control) operation will not be guaranteed.
To use this function, you must select the TV/CD input selector and your TV must be ARC Capable.
If you set "Audio Return Channel" to "Auto", the "Audio Selector" settings of the TV/CD input selector will be automatically switched to "ARC" (-> page 55).
Suggest to reassign HDMI-7 to "CBL/SAT" or connect HDTV PVR decoder to HDMI-3 (CBL/SAT).
