Originally Posted by
oleus
thanks d bone - that's the firmware i'm running too. and i guess i can rule out the mic being a problem too.
now...i *did* set up all of my inputs, rename sources, etc, before running the audyssey calibration. and i probably did have another cable plugged into before running the firmware update, are those steps necessary?
wondering if a factory reset would be worth trying.
I downloaded the manual, and read it cover to cover several times before my unit arrived. At least twice, the manual states that the power cord should be plugged in last, after all connections are made, both cable and speaker.
Before I bought my 709, I read about HDMI failures and the like, so I made sure that my unit was completely and entirely hooked up and moved into place before I powered on the unit.
Maybe a factory reset followed by and update, then power down, then hookup and move into place, followed by a power up would "fix" it? Depending on how hard you unit is to move, and re-cable, I think you would have nothing to lose.
Also, before you do the above, could you describe your mic set up procedure step by step?
