AVS › AVS Forum › Audio › Speakers › Bose 601 Series I: Need repair advice
Bose 601 Series I: Need repair advice - Page 2
post #31 of 42
Originally Posted by schan1269 View Post
I was selling AV back when the first AM3/5 were being sold, then shortly thereafter the AM7.
I asked a point blank question(cause if you remember DSP was also in it infancy)...
Will the Bose AM series work with DSP modes? (this after we heard the de rigueur speak from the talking heads about their proprietary circuitry)
"Bose does not recommend using EQ in the receivers, and DSP are a form of EQ."
I was selling it around the same time. And yes, while they were truly "epic" in the way we presented them (sheets hung over what looked like huge tower speakers...and then revealed to be the cubes and hidden module after demo), the AM3s couldn't handle much more than the avg 100w system at moderate levels before revealing the real limitations of the isolated cubes. And oh, hell yes, an EQ or expander would have killed them. These systems are for people like my parents .
I've never...to this day...been a fan of sat systems, and I even rue the day everyone has gone to these 6" drivers, only to HAVE to purchase a SW to go with them. It's BS.....but it makes a wife happy (and others with limited space issues).
Next question, by another person...
What is the determined delay cause by the direct reflecting technology? Do you have a chart for angles and wall distance?
"Bose Direct Reflecting technology does not create delay"
I'd bet dollars to donuts the Bose reps you had were morons, because I know damn well they do have such charts. No, not about to go look them up for anyone, but I'll stand by my remark. I was lucky enough to have some pretty slick Bose reps and see some pretty cool demos. Sure, some smoke & mirrors, but still...impressive in essence .
post #32 of 42
So dbx123, the anechoic sweep graph by S&V means nothing? OOOooooookayyyyyyy......
post #33 of 42
No, it's your hatred that means nothing, not the scattered, actual facts that are strewn amongst the BS in that hack job of an article that you posted .
Only a tool builds a case with "ten pages" of BS..and then tries to claim legitimacy based on a sentence or two of said hack piece.
You, my friend, are fitting nicely into that "tool" category.....all by yourself.
Again...and most seriously...I respect the fact that you don't like..er..hate Bose. I don't think you really understand this point .
post #34 of 42
Sure. Ok. If you want to keep thinking that garbage is good, then more power to ya pal.
post #35 of 42
Well, guys...at the end of the day, the OP didn't ask any of us what we thought of Bose!?
post #36 of 42
This is true.
post #37 of 42
Originally Posted by gjwinner850 View Post
I am a newbe in this forum and searched before posting, so forgive me if I missed a previous post on this subject.
Just pulled my old Bose 601's out of the closet after 10 years. I bought them in 1977 brand new. The Rubber cones were bad on the woofers when I put them away ( couldn't force myself to sell/throw out). Does anyone know how I can repair or replace the woofers in them?
Are they worth repairing ?
Always thought they had great sound, would like to fix and start using them again.
Thanks in advance
I have no idea where you are located, but if near Dallas, TX this place has a very good reputation.
http://freemantuell.com/
post #38 of 42
Hey All, I know this is an old thread, but I have some questions. I ordered a set of foam surrounds for my FiL's BOSE 601, series II. He bought them new back in the '80's, while in Singapore. He also has a set of 901’s (I think), but prefers the 601's. I have seen YouTube vids showing how to replace speaker surrounds, but have never done so myself. So for my FiL's B.day, the vife and I thought it would be great to get his 601's back up to spec. I have ordered the surrounds(x4), it comes with some glue, but I am sure that it is only a token amount, and not substantial. What tools, will I need to remove the old surrounds (putty knife, razor blade, etc...?) What is the best way to remove all of the old surrounds still attached to the driver? (A solvent or just the above?) Is it necessary to remove the dome's dust cap, and if so, what is the best way to re-attach? Also, as mentioned, the surrounds come with glue, but is there a more specialized type of glue that I should use? Epoxy, Rubber, Super, etc…? Lastly, since this is a Birthday gift to my Father in Law, what other things should I do to the speakers to make them whole again? I see that these have four tweeters per speaker, is there something that I can do to those, that would help them along? Any help is appreciated, Thanx.
post #39 of 42
The glue that came with the repair kit is the proper glue. You only need a thin layer so it's probably a sufficient amount. If the foam surrounds are really deteriorated, the you can just kind of scrub it off with your fingers. I've never taken off the dust cap. But if you don't, make completely sure to cone is 100% centered before you let the glue set. I just glue the inner portion of the surround to the cone first, let it dry, and then put the glue on the basket. Then I push the cone up and down a few times, this should automatically center it. What you're listening for is to make sure you don't hear the voice coil rubbing against the sides of the magnet. Once you accomplish that, use your clothes pins, clamp the surround to the basket, let it dry, reinstall and you're done!
Easy Peasy!
post #40 of 42
Thanx for the quick reply. We will be up at the family fish camp in AR, for his B.day, and will not be near any civilation. So I won't be able to go down to any local *Marts(Wal, K, etc...) for any needed supplies. I will be bringing my toolbox, which has most major tools, but is there any specific tool that I might need? I know that the BOSE 601's have two 8" drivers. The one in the body seems simple enough, but the suspended top driver, I have no clue how it is attached. Any suggestions on how to approach the top driver? Either way, I figure that I'll bring everything I have (you never know when you just might need some random tool), and I hope to be over prepared, but I would hate to go through all of this trouble, only to find that they used "Wentworth" bolts(Cars 2 reference). Thanx for any and all help.
post #41 of 42
Regular tools are all you need along with a bunch of the spring type clothes pins. The top driver to me looks like its just set in a bracket with four screws.
Look at al the images here, it might help you figure it all out:
https://www.google.com/search?q=bose+601&source=lnms&tbm=isch&sa=X&ei=p2fcUZWKDYXm8QTr44GoDw&ved=0CAcQ_AUoAQ&biw=1600&bih=775#imgdii=_
post #42 of 42
Thanx FF.
I scrolled through and saw exactly what I needed to see.
It looks like just 4 screws.
I'll post back afterwords, or if I have any further ?'s.
Thanx, again.
  Back to Forum: Speakers
