AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › HTPC Gaming › Connect Mac Pro to HT
post #1 of 5
Hello all
I see there are many people connect their PC to their HT for maximum entertainment. I like playing PC games under Win 7 ultimate 64bit, which is installed at my Mac Pro. The question is; how do I connect my Mac Pro 2009 model to my HT? To be mainly used for Windows Gaming.
I have Marantz SR7005 and below is the Pic I took from one of the websites for the Mac Pro
Your opinions!
post #2 of 5
Use a DVI-HDMI cable to carry the video signal directly to your TV (or to the Marantz if you wish); and an optical cable connected to the Marantz 7005 for the audio signal.
post #3 of 5
Can any optical cable be good? does it support 5.1 HT or not?
post #4 of 5
Any regular consumer optical audio cable (the Toslink style) should work. You should be able to get 5.1 sound, though a trip to System Preferences may be necessary to get set up correctly.
Fwiw, I use a mini-Toslink to Toslink cable with my MacBook (the 1/8" headphone jack doubles as an optical output) and have no problems with 5.1 output.
post #5 of 5
Many Thanks for your kind response
  Back to Forum: HTPC Gaming
