AVS › AVS Forum › A/V Control & Automation › Tweaks and Do-It-Yourself › Coaxial A/B Switch
Coaxial A/B Switch
post #1 of 4
I bought a Samsung UN22D5000 two days ago to replace a Samsung LNT1953H TV/Computer monitor. The older one has two F connectors for coaxial cable, but the newer one has only one. Because I like to have both an over the air antenna and DISH network, I need twin coaxial cables. I bought a cheap Philips A/B this weekend and found it to be very lossy. Some much so that when I connected either cable by itself everything was fine, but simply adding that switch and a short 3 foot run of RG-6 the over the air channels pixelate. I suppose it could be the patch cable or the switch. At any rate I am know wondering if all A/B switches are created equally, or if some are more lossy than others. And, if that is the case, what are some better switches that won't lose as much signal?
post #2 of 4
I have heard electronic switches can be lossy, mechanical switches much better, if u don't do this often and don't mind getting off the couch.
post #3 of 4
Simple answer is why are you running coax from your dish box to the tv in the first place? Use the HDMI, Component, Svideo, or Composite. Any would be a huge improvement in picture and sound.
post #4 of 4
The DISH 722k modulates on either NTSC or cable channels, so I selected to cable channels and I have RG6 on all three levels of the house to tune in either TV1 or TV2 content from the DISH satellite receiver. I suppose I could replace the RG6 with multiple runs of HDMI, Component, Svideo, or Composite, but I think it would get pretty expensive. I think that it would even be better if the 722k sent it out via ATSC through the RG6 that the recovered content would be better, but I doubt that will happen.
  Back to Forum: Tweaks and Do-It-Yourself
