Did someone use envirotex (or any compound similar) on tile. My tiles are not exactly all level and a was thinking to use envirotex to add ''level'' the top
Better explain your situation. Paint doesn't strike me as a solution for leveling tiles, but them I don't have a clue what tiles you are talking about or why they aren't level.
When i did the top of the bar some tile are a little bit higher. I was thinking that if i'm putting a transparant compound on the top, it would fix the ptoblem (sorry for my english)
