Incredible Power and Efficiency in a Compact Package
Mobile professionals and on-the-go presenters alike will appreciate the compact
design and vivid LED performance of the Optoma ML500. Delivering 500 lumens
of brightness and WXGA resolution, this projector creates crisp, clear
widescreen images of up to 120 inches on most surfaces. Built-in media and
Microsoft Office document viewer allows for playback of videos, presentations,
documents and images directly from the projector’s memory, while HDMI
provides quick connection to the broadest possible range of devices.
Features
Truly portable at under 3 pounds
Project large widescreen images of up to 120” diagonal
2000:1 contrast ratio for detailed images
LED light source lasts over 20,000 hours while producing excellent color
DLP Pico imaging technology
Direct playback of movies, photos and Office files
Directly display through USB
2GB on-board memory; SD card slot allows for memory expansion up to 32GB
VGA and HDMI inputs – Connect to laptops, Blu-Ray players, and game systems to display content
Specification
Projection Type: DLP
Resolution Native : WXGA (1280 x 800)
Maximum Resolution : WXGA (1280 x 800) through VGA, 1080i through HDMI
Brightness : 500 ANSI Lumens
Contrast Ratio : 2000:1 (Full On/Full Off)
Light Source : LED (RGB)
Estimated life of over 20,000 hours
Throw Ratio 1.4:1 (Distance/Width)
Image Size (Diagonal) 17” to 120” (16:9 native)
Projection Distance 21.7” to 127.2”
Aspect Ratio 16:10 Native; 16:9 and 4:3 compatible
Offset 105%
Memory 2GB On-board memory; SD slot supports up to 32GB SDHC
Displayable Colors 100% NTSC Color Gamut
Pre-Launch Datasheet – ML500
Audio One 2-watt speaker
Computer Compatibility WXGA, XGA, SVGA, VGA, VESA,
PC and Macintosh Compatible Video Input Compatibility
NTSC, PAL, SDTV (480i), EDTV (480p)
Video File Compatibility H.264 (AVI, MOV, MP4, 3GP), MPEG4 (AVI), Xvid (AVI), MJPEG (AVI)
Image File Compatibility JPEG, BMP
Office Viewer Microsoft PowerPoint, Word, Excel, .txt, Adobe pdf
Audio File Compatibility AAC, MP3, PCM, ADPCM, WMA
User Controls
Complete On-Screen Menu
Adjustments in 10 Languages
I/O Connectors HDMI, VGA-in, Composite Video, miniUSB, USB, SD slot
Projection Option Front, Rear, Upright, Inverted
Weight < 2.5 lbs.
Dimensions (W x H x D) 8.7’’ x 1.7’’ x 6.7’’ (220mm x 42.5mm x 170mm)
Operating Temperature 41° to 95°F (5° to 35°C)
Noise Level : 38 dB
Power Consumption 120 Watts max (Bright mode with multimedia function)
Warranty 1-Year Limited Parts and Labor
Standard Accessories AC Power Adapter Cord, USB Cable (Type A to Mini
USB), Bag
Optional Accessories : TBD
UPC : 796435 41 721 5
Price and Availability : The Optoma ML500 will be available in September at a price of $699.
Features
Specification
Offset 105%
User Controls
Weight < 2.5 lbs.
Noise Level : 38 dB
USB), Bag
