AVS › AVS Forum › Display Devices › Rear Projection Units › Mits 46807 Convergence Question
post #1 of 4
I have a Mitsubishi 46807 HD TV and the convergence is off a little bit at the top right of my screen. I tried the manual 64 point convergence and it won't do the trick. When I put the manual convergence pattern matrix on the screen it seems that there is a gap at the top (meaning, I believe the whole projected image should be moved up somewhat). Does anyone out there with this set know if a service technician can adjust this through a service menu with having to tear the set apart? Thanks.
post #2 of 4
check out the Mits-Tweaks forum at www.***************.com
by far the best resource for mits info...
post #3 of 4
Check the mits forum for DIY fixes. But the answer is YES, a [competent] service tech can correct this without opening the TV. Since many techs are not compentent, I would DIY or pay for a full calibration. Checkout the spot for a recommended calibrator in your area.
post #4 of 4
Thanks for your inputs. I had a service tech come and through the remote control he accessed the service tech menu and adjusted the vertical height and all came out fine. Thank God you can make those adjustments from the remote control menus without having to open up those units.
  Back to Forum: Rear Projection Units
This thread is locked
