Well the game is coming on soon and I have some Brats to throw on the grill which is only fitting for this season opener.
As I mentioned earlier I called Onkyo tech support this afternoon. To my surprise I was speaking with Sal in tech support within 1 minute. Amazing. Sal spoke good english with no accent and seemed knowledgable. That is the end of the good news for now. Once I described my problem Sal made some suggestions but his overall opinion was that I have a faulty unit and should try the suggestions but in all likelihood will need to make a warranty claim. Yep, that involves taking it or sending it to an authorized service center. I let that go for now because this thing is 2 months new to me and be damned that I want a repair for something that shipped faulty let alone pay shipping for that.
Now to what he suggested:
1. How long is the HDMI cable? It was a 6 footer so next.
2. Can you try a new cable? I will but it does work after some time.
3. Try using menu and setting output to 1080i instead of 1080p.
4. Disable and bypass the video section of the AVR.
5. Do a hard factory reset.
6. Call us after you do all of those things because I think you have a faulty unit. Handshake should take less than 20 seconds most.
Well I spent some quality time messing with the picture options in the menu. For the most part no change. Occasionally it comes on like it should but no pattern. Of course I swapped cables first. Anyway, the thing works, it just takes a while most of the time and now I have the big screen down in prep for the game so end of story for tonight. Obviously I am not doing a factory reset because I do not want to rerun audyssey right now. So it is somewhat annoying but everthing seems to work and I am going to watch football in 1080p with surround on a 120" screen tonight.
