AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Onkyo TX-NR809 Thread
"Official" Onkyo TX-NR809 Thread - Page 6
post #151 of 5255
I missed out on the previous discounted price from NewEgg (they were out of stock by the time I found out from my price alert) but I was able to pull the trigger today!
post #152 of 5255
By the way I found these on Amazon (didn't order them):
Onkyo UWF1 / UWF-1 / UWF-1 Wireless USB Network Adapter
http://www.amazon.com/Onkyo-UWF-1-Wi...ref=pd_sim_e_1
$39.98
Onkyo DS-A4 Remote Interactive Dock for iPod/iPhone (Black)
http://www.amazon.com/Onkyo-DS-A4-Re...ref=pd_sim_e_3
$114.88
post #153 of 5255
Not sure if this has been posted...
I got my order confirmation from NewEgg and it said:
1 x ($699.00) RECEIVER ONKYO TX-NR809 R
First thing I thought of when I saw the 'R' after the model number is, does that indicate it's a REFURBISHED unit?
Anyone? Bueller?
post #154 of 5255
My neighbor got one and I set up last weekend aand it appeared new. Not sure if there was an r on the model when he bordered the weekends before.
Mike.
post #155 of 5255
Something -DOO? Anyone? VooDoo economics. Love that movie!
Ordered one today as well...have the same "R" on the order confirmation. Nothing on the sight that I could find that said either new-in-box or refurbed. Just e-mailed them about this, but probably won't hear back until Monday.
post #156 of 5255
Anyone? Bueller?
Probably not, mine was absolutely not refurb.
post #157 of 5255
Originally Posted by mtrot View Post
Do you think this will be an audio quality upgrade over my Yamaha RX-V1800? Specifically, I mean audio quality for 2 channel music as well as Blu-ray movies.
It does not seem to have that much separation of channels, and the center channel in particular seems weak and lacks dialog clarity, no matter how high I set the level.
Also, the best way I can describe the sound quality of the Yamaha is "analytical" or "sterile".
My speakers are Front: Legacy Signature II towers, Center: Paradigm cc570v3, Surrounds: PSB Image T4, Sub: Outlaw.
Any input much appreciated!
The Yamaha would be best described as "bright" rather than sterile. The 809 is more well rounded, possibly a bit more towards the warm side. Would be a much better match with Legacy's. Bi-amping will run them nicely. I have a pair of Infinity Renaissance 90's bi-amped on the front R+L. The 809 is not a match for the Citation 7.1's I pulled out of my system, but it is as good as any receiver I have ever heard including the Anthems. I will try the rec as a pre/pro and report back. The 809 surround processing is excellent. The video processing is astonishing at the price. You MUST run Audessey to get the system to work right. (These are only MY opinions, of course)
post #158 of 5255
Same here except I did not email them. I know they would not send me a refurb because they would get it right back or have to knock a bunch of money off of it. I choose to think the R is for retail. Here is to hoping Onkyo sorted out the issues with the other models or I will be living the nightmare too instead of the dream.
post #159 of 5255
Originally Posted by Mikes2cents View Post
1. Same here except I did not email them.
2. I know they would not send me a refurb because they would get it right back or have to knock a bunch of money off of it.
3. I choose to think the R is for retail. Here is to hoping Onkyo sorted out the issues with the other models or I will be living the nightmare too instead of the dream.
Agree on all 3 points
post #160 of 5255
"B" means black face plate, not "B" stock.
post #161 of 5255
Thanks Joe. The letter we're talking about is "R"
post #162 of 5255
Any idea on how much heat difference there would be between the 809 and the older 607? I can give the receiver a little over 2" head clearance in an open style stand (no obstructions on the sides, back or front).
post #163 of 5255
I have had the UFW-1 for a couple of weeks now. I think it totally rocks! Now I can have the 809 on the DLNA and stream music from my phone
post #164 of 5255
How does the 809 compare to the Onkyo HT-RC180 in terms of sound quality? What is/are the major difference(s) btwn the two onkyos?
post #165 of 5255
I answered this is another thread you asked in already.
"Well it's missing lot of the quality in some aspects. Say the new video processor is supposed to be better than the Faroudja. It's missing Audyssey MultEQ XT, which provides better sound. It's missing dual hdmi outputs. Basically many bells and whistles are missing and some slight quality improvement features are missing. I mean what you expect at twice the price. If you don't care about quality or features HT-RC180 is a nice unit.
It also doesn't have a learning remote. Has no phono input either."
post #166 of 5255
Yea, I know, just thought the next question would be about the "B".
post #167 of 5255
Hi,
Thinking of the 809 or the Denon 2312CI. Denon has Airplay built-in
Since Onkyo seems to be updating the firmware frequently (just added Spotify) is it technically possible for them to add airplay support in a future firmware release?
post #168 of 5255
Thanks for the reply, and I'm glad to hear that the 809 might do well with the Legacys. I actually installed a 608 at my folks house a couple years ago, to go with a very old set of Legacy towers, and it just sounds great. Much better than my Legacy Signature IIs do with my Yamaha. Yes, I know it is a totally different room and acoustics.
post #169 of 5255
Does anybody know if ISF is global or assignable?
post #170 of 5255
How's the heat on everyone's? Mine seems to be great. It's a tight fit on my tv stand, and I check the glass above it periodically. It's warm to the touch, but nothing like people have said. The heat can escape the sides, but there's less than a 1/4" above the receiver.
post #171 of 5255
Keep telling yourself that, it's an onkyo. I wouldn't even trust it being warm at this point. As for ISF it's assignable per input.
post #172 of 5255
Apparently Amazon matched it. I had been looking at getting a 709 and then was just cruising this thread. Looks like I'm getting an 809 now!
post #173 of 5255
Yea you'd have to be a retard to buy a 709 over the 809 when there is a $50 price difference.
I just hope it doesn't end up screwing me 2 yrs later like the 876 ended up doing.
post #174 of 5255
So an electronic device isn't supposed to get warm? C'mon-I know Onkyos have a bad rap, but you sound paranoid. Overreact much?
post #175 of 5255
post #176 of 5255
How's that?
Also, I asked this in the 709 thread since I was thinking about getting the 709, but with the 809 on the way maybe I should ask here: I read on a review site that the receiver draws 38W while in Standby mode if the HDMI Through Mode is active. With the recent firmware updates, is this still the case? Anyone have experience with this? Thanks.
post #177 of 5255
Wow, glad I checked this when I got home. I just cancelled my egg order and got it from Big River and saved sales tax. Used the $3.99 Prime 1 day shipping too so whoot. GOOD NEWS for me.
post #178 of 5255
Just did the same. Woot!
post #179 of 5255
Not to the extent my 876 got hot. Why do you think they had so many dead HDMI boards. The cooling fans don't even kick in until it was insanely hot. You better live at the south or north poles if you don't want your unit to melt. I'm speaking of the 876 years models. It's widely known they get super hot. Go read the thread. From day one people were like what the hell, and putting their own fans on the units to keep cool. Which I did too and yet it still failed 2 yrs later, so much for that $1700 receiver.
I hear these units are much cooler, I'll know in one more day. But paranoid, I think not. Their heat track record speaks for itself.
post #180 of 5255
Bah - this would have been my preferred route too. Oh well - I've ordered plenty of stuff off Newegg and never had problems, so I'm sure I'll be all set.
