Originally Posted by
GregF
It does say "net". Sorry where do I find this menu elsewhere? Only had the unit for about a day!
I am not sure of your question. Are you aware that the first few menu items (Monitor i/o, Speaker...) etc are Global. When you get to Source Setup, that is unique to the Source you selected BEFORE you entered the Menu System. the label should be at the top.
EG, goto DVD source, and then Menu, and then Source Setup. You will then be setting up JUST the DVD source. Picture Adjust, I think, is number 5.
If you start in "NET" as the source, there is no Picture Adjust option.
For info - when you are in the Menu system as described above, you can change Sources to check settings in other Sources (hope this last bit doesn't confuse - it did me and i wrote it).
