Originally Posted by
½Baked
The 609 is awesome for $399. Its not even close to the 809. The difference is not just the power or features, its the actual sound quality. I think you would be disappointed with the 609.
Thanks for the feedback! The 809 just arrived today! I guess I am interested in finding out how this would compare to my Denon 2809CI which I have only had for a couple years now. I dont want to spend a ton of money to have a small benefit over the receiver I already own because the Denon really does an awesome job. I just get sucked in to spending money because it's a "good deal". My biggest concern would be that it didn't have the same sound as the Denon that I have gotten to enjoy through my home theatre set-up. I would crack the box open to test and compare w the Denon but I think Amazon would charge me a restocking fee if I decided to then return. Any additional feedback is appreciated! I am attaching specs for the Denon receiver to see what you guys think:
The AVR2809CI is a 7.1 AV receiver with video upscaling to 1080p of analog sources using a Faroudja DCDi chipset, decodes high-definition audio sources (Dolby TrueHD, dts HD-MA), and features 4 x HDMI 1.3a inputs with Deep Color support. A notable upgrade to the previous-generation is the addition of Audyssey's Dynamic Volume processing along with the already present Dynamic EQ option. Dynamic Volume is found on all ten models; it's a feature that levels the volume to a more-or-less constant level to avoid sudden changes in volume. This feature works together with the Dynamic EQ that dynamically adjusts the EQ settings to optimize the dynamic range.
The built-in Audyssey MultEQ acoustic correction technology and optimization system custom-tailors the sound for optimum tonal balance throughout the listening space. To eliminate irritating swings in volume between TV shows and commercials, the AVR2809CI is one of the first to offer Audyssey Dynamic Volume automatic volume-leveling system, as well as Audyssey Dynamic EQ to ensure rich bass and smooth tonal balance, even at low volume levels. With the Denon AVR2809CI you get loads of connectivity for system building, including HDTV-compatible component video switching. A front-panel audio/video input allows quick and easy connection of camcorders and game systems. Analogue video to HDMI scaling to 1080p, 1080p video pass through Multi-Zone 2 source/2 Zone capability.
Options to Expand
Expansion options abound, with media network connectivity (via optional ASD-3N/3W), along with iPod compatibility (via optional ASD-11R/3N/3W), and the AVR-2809 features Denon’s exclusive Compressed Audio Restorer that automatically improves the fidelity of your favorite portable audio tracks.
Technical Specifications:
Power Output: 115 watts/channel
Dolby Pro Logic IIx – with Cinema, Music, Game Modes: Included
Dolby Digital Surround EX Decoding: Included
dts ES Discrete 6.1 Decoding: Included
dts ES Matrix 6.1 Decoding: Included
dts Neo:6 Stereo-to-Surround Cinema and Music Modes: Included
dts 96/24 5.1 for DVD-Video Processing: Included
dts-HD Master Audio: Included
Active Center Channel In All Surround Modes: Included
Pure Direct/Direct/Stereo Modes on Digital/Analog inputs: Included
Wide Screen 7.1 Mode: Yes
Assignable Digital Inputs: 7
Digital Inputs: Coaxial: 3
Digital Inputs: Optical: 4 (including one in front)
Digital Outputs: Optical: 2
Analog Audio Inputs, Incl. Tuner: 11 (including XM)
Phono Input: MM type
Analog Record Outputs: 2
Composite Video Inputs: 7 (including one in front)
Composite Video Outputs: 2 (plus Mon/Z2)
S-Video Inputs: 7 (including one in front)
S-Video Outputs: 2 (plus Mon)
Component Video Inputs: 2
Component Video Outputs: 2 Main Zone
Weight: 28.2 lbs
Width:17.1 inches
Height: 6.75 inches
Depth: 16.55 inches
