Originally Posted by
BOTTLEDZ28
Quick question guys. When playing back a bluray movie that has the DTS HD MA logo what should the AVR have displayed? Mine is saying Multichannel. I cannot get it to display DTS at all . The bluray player is outputting the DTS signal per the on screen display. I am running a 5.1 FWIW.
Assuming your Blueray player is connected using just the HDMI cable?
You need to make sure the audio setting on the
DVD/BD player is set to Bitstream or Digital Pass Through. (same thing)
When you get the audio setting on your
DVD/BD player changed to bitstream and play a movie, the Onkyo will automatically select the correct surround mode. It will actually change a few times because a DVD/BD movie's menu is usually in a different surround format than the movie itself.
When working correctly, it will show the surround mode that its in on the Onkyo's display. You'll see it switch as you go from the disc's menu to watching the movie.
