I am trying to help a friend combine dish and ota into a single cable.
1.OTA antenna cable goes directly to the TV antenna input.
2.he has a dish 322 dual tuner box. a single cable from the dpp33 switch goes to a Holland splitter that has two labelled ports:
1. uhf/vhf
2. sat
the SAT cable from that splitter comes to the dish box, then gets split to feed two tuners on the dish box(the splitter on the box is labelled "dpp seperator").
the second tv in another room gets fed with the uhf/vhf cable and works on channel 73. i checked that this channel number can be changed to any channel one wants to use.
is it possible to combine the two into one cable?
1. uhf/vhf
2. sat
