My theater room is in the basement which allows me to have a completely dark room. Given that I'm unsure what I should go with for a paint recipe. I have been reading through numerous posts with paint recipes and I just don't know which one is right for me.
I purchased the following based on a post from MM (http://www.avsforum.com/avs-vb/showthread.php?t=1310840) as it looked like it was simple enough. Turns out our local Michaels is discounting CeramCoat White Pearl so I hope I can find it again if I run out.
Given these details, what would work best for my setup? How much will I need for the screen size I have? I'm setup to roll the above recipe with a 1/4" nap roller, is there another low cost alternative?
Thanks in advance!
My setup:1 quart Behr Premium Plus ULTRA UPW Interior Enamel (Flat)
1 pint Minwax Polycrilic Water Based Polyurethane (Clear Satin)
16 oz Delta CeramCoat White Pearl Finish. (Michaels Arts & Crafts)
8 oz. Water (Distilled or Filtered)
- 12.5' x 14' (WxL)
- 100" 16:9 MDF Screen (49"x87")
- Light controlled
- Sony VPL-AW10 (hoping to replace this in the near future)
- Dark wall color, black on ceiling
Thanks in advance!
