Originally Posted by
pmcd
Are you sure you used the right beta? 901f I think. SMB and DLNA work with it as will mkv containers with h.264, etc ... The cannot play the media was with some other firmware.
Yes, 901f. I have just .mpg and .m2ts and
they do not play. Plex only ever played one, but without sound. SMB and DLNA no longer work, at all---that was the point of my post. Do you think I imagined this?
In any case you can go back to other firmware.
I have, without improvement. No network function at all. It just crashes.
With Plex you can filter your selection to just added, recent, and so on .... It will handle libraries of your size. I must be missing something but I see far more than 5 posters at a time. More like 20 or more.
I see only a handful. Most of the screen is occupied by metadata and synopses, which should not be presented at the top level.
You can reset the st600 and try the 901 beta. 198 does not contain the Plex fixes.
I guess you missed the point that I've tried all this--without effect.
Sorry if I sound testy, but I've already covered all of this. Perhaps it needs service.
In any case, I really don't care at all about Plex--I normally stream with a Dune Smart D1 or HTPC/XBMC--but was simply curious. I don't need the SMB or DLNA functions of the ST600 either--I bought it for Vudu and Amazon--but am annoyed to have lost them without gaining anything.
