AVS › AVS Forum › 3D Central › 3D Displays › Mitsubishi 3D adapter works on Samsung with NO Gefen and no EDID reprogram!
post #1 of 3
Via a simple reset, the EDID restrictions are removed from the 3DA-1 adapter, allowing it to work with Samsung DLP 3DTVs.
Thanks to PaulGo, FronzDan, PlumB and especially Justin-Dawson!
http://www.avsforum.com/avs-vb/showthread.php?t=1341216
1. Power off the adapter (leave everything plugged in and connected)
2. Press and hold the 3D Mode button then press and hold the Power button
3. Observe the 3D status light until it blinks. You want it to blink once, if it blinks twice (5 seconds apart) then restart at step 1.
4. After you get the unit to blink once, release the Power button then release the 3D Mode button.
post #2 of 3
Has anyone else tried this?
post #3 of 3
Confirmed to work in the other thread.
  Back to Forum: 3D Displays
