AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Samsung 2011 PNxxD530 Thread
post #1 of 48
I've done a lot of searching online and haven't found a whole lot of information about this TV. I recently bought the PN51D530 model and absolutely love it and want to hear from others that have it too.
Some things I'm looking for:
-Calibration: There's nothing on calibration that I could find so I looked at a couple of similar model's calibration numbers over at televisioninfo.com and found what I think are some decent settings.
--PN51D450: http://www.televisioninfo.com/conten...alibration.htm
--PN51D550: http://www.televisioninfo.com/conten...alibration.htm
The calibration options are virtually the same for these two models so I figure they should translate decently over to the 530.
-Model Comparison / Reviews: Any kind of model comparison or review would be great. I think this model looks great but this is my first plasma.
Also, the advanced calibration mode (Mute, 1, 8, 2, Power) works on this model. I'm not sure if there is anything in there worth changing but I could be wrong.
post #2 of 48
This TV is virtually the same as the PNxxD550; I couldn't find any difference, but there has to be at least some very small difference(s), in order to create another model number (for certain stores that carry this TV).
This TV line really shouldn't have it's own thread. Try the D550 thread, there is a lot of info. there. If you were to post there, and point out that the D540 is very similar, others with would follow. Regardless, the D550 should be very helpful.
post #3 of 48
I was also at Costco and in the same dilemma. Maybe, it's better to ask the
PNxxD550 advanced calibration unlocked!/Calibration Thread
post #4 of 48
The D530 is basically the same as the D550 but without 3D and has fewer HDMI inputs.
post #5 of 48
Oops...I noticed no 3D right away, but since I didn't (and don't) care about it, I was looking for other differences, and neglected to mention the obvious.
post #6 of 48
i'm thinking about upgrading my sammy 42" 720p plasma with this model this week.
any other posters out there have advice on this one? good, weird or bad?
post #7 of 48
I picked up a PN51D530 last night, no need/desire for 3D and 2 HDMI inputs are all I need. I only have about 1 hr on the set so far, I have not even found the calibration menu/screens yet. On 1080 material... it looks excellent, on the 720 material, it looks very good, on SD material.. it looks like a cheap pos LCD tv. The SD material is a bit disapointing. This is using a direct cable connection and a ROKU box as feeds. After looking at the screen at Best Buy... I was real concerned about reflections, they were very obvious and annoying in the store. Luckily, at home where I have the tv placed... I have none. No sign of buzz so far. In between some scenes where I expected the screen to go black.. it went gray, but during a show things that should have been black.. were a good deep black. Except for the SD picture, I am very happy with this set, it is a keeper. Now to find the calibration screens and see if I can't make the picture even better.
post #8 of 48
I just bought this tv last night as well. I was debating on whether to spend $100 more for the 3d capability but I still feel its kind of gimmiky. When i was researching this i kept hearing that it is basically the same as the 550 but, i am wondering why the cell light only goes to 10. Does that mean we should set it at 5?
post #9 of 48
The cell light on the D530 goes to 10, whereas on the D550 it goes to 20. Also, the D530 has the older Samsung menu interface, whereas the D550 has the newer menu like the Smart TV models but without the internet apps. But I wonder if the internet apps could somehow be enabled on the D550 in the service menu, as the network settings menu is there.
post #10 of 48
I guess I should have gotten the D550 then. Oh well, I opened the service menu but i don't know enough about this stuff so i didn't mess with anything. I think i will pay to have it calibrated at some point. Thanks for your input.
post #11 of 48
Are the panels for D530 and D550 the same?
post #12 of 48
They are similar. However, there are only 2 hdmi inputs and one component input. It only has a 2 point scale instead of 10 point if you were going to callibrate it. From what i am getting the menu has last years version so there are differences in that regard
post #13 of 48
They are both nevertheless very nice displays, but the D550 does have more features and calibration options. And this week thru Thurs, Fry's has the 51D550 at $799, which is the same price the D530 has been going for.
post #14 of 48
I wish I could get 51D550 for $799 in Canada... I think the best I saw was $899.
So from what I gathered the differences between D530 and D550 are GUI with less options to tweak, less HDMI inputs, 1 less USB input and no 3D capablility however the plasma panel itself should be the same.
For my needs D450 720P would be fine right now, but in a long run D550/D530 1080P would be a better investement.
post #15 of 48
Does anyone have any settings for their tv. I use it for xbox and am curious to see if my settings are close to what others have. I am considering a professional calibration but i am not sure if it is worth the cost.
post #16 of 48
HHG has PN51D530 on sale at $749 in store later this week.
post #17 of 48
Im in Winnipeg and Visions had a thanksgiving sale on the D550 for $798 and I got Sears to match it. So for once Canada's prices are competitive with the states!
post #18 of 48
I just bought the PN51D530 today. I have it hooked up to a Blu-Ray player so far.
While watching a Blu-Ray, I push the "Info" button on the remote and it tells me that it is "@24hz".
How do I get this thing at 600hz?
post #19 of 48
Is there any new firmware for D530 that fixes increased black levels in the last official one? For the other models of the series, there are new firmwares.
I got the european version, PS51D530 with the 1007.2 fw from november. In USA the latest is 1007.0 from october. Any clue?
post #20 of 48
Where did you find the 1007.2 Euro firmware? I looked on there site and couldn't find it.
Found it:
http://www.samsung.com/nl/support/mo...downloadName=#
Do you know what was upgraded with this firmware?
post #21 of 48
1007.2
http://www.samsung.com/es/support/de...rd=PS51D530A5W
If I were u, i'd think twice about upgrading if you have decent black levels.
post #22 of 48
Hey Everyone,
Recently "upgraded" from a 54-month old LN-T4661F 46" LCD to a PN51D530 (D550's poor-ass cousin).
Everything I've been able to read as far as the internals on the D530 are the same as those of the D550 -- my simple question is can I run the 1019.5 firmware on my D530? I'm annoyed by the "pops" that happen quite often.
Thanks in advance (I did look through the various posts and couldn't find anything concrete).
[I also posted this over in the D550 thread just in case somebody else there can help me out]
post #23 of 48
Forum,
I just purchased a PN51D530 in the US and applied firmware 1007.
1. Does this TV have Anynet? The Samsung site says yes but I can't figure out how to enable it.
http://www.samsung.com/us/video/tvs/...30A3FXZA-specs
2. Can you unlock advanced menus using the D550 methods? Are there pros/cons to this?
Thank you,
AMT
P.S. I definitely think this TV deserves it's own thread.
post #24 of 48
Anyone have color issues with this set ? My primary complaint is with Red seems oversaturated and tinted towards the pink side, not sure what if anything can be done about it ?
post #25 of 48
Another D530 owner.. (PN59D530 from Costco in Canada). Also posted in the 550 thread about the brightness pops and firmware updates.
Has anyone with a D530 been able to enable film mode? Playing a blur-ray (LOTR) from a PS3 (80gb fat) via HDMI, the TV shows 1080p@24hz, but the option for film mode is greyed out, irrespective of which mode I choose. I found it a bit jerky too, especially on wide scenes with a lot of panning.
TIA.
post #26 of 48
That particular film mode as far as I know is only enabled for 1080i content. The Samsung specs say this set has Cinema Smooth but I havent been able to find that option anywhere, my guess is that the specs are wrong and this set does not have it.
post #27 of 48
Thanks - you're right, different to what I'd heard previously. Not entirely sure what it does, I'll leave the WDTV to auto, and the PS3 to 1080p..
On a related note, HDMI black level is still, and always, greyed out too - any idea if that's also related to signal input?
I don't think it has cinema smooth, I can't find Anynet+ either, I don't think the Samsung specs are correct - I suspect most of this is disabled to justify the premium for the D550. I don't like / want 3D, hence the D530...
post #28 of 48
My understanding is that the HDMI Black Level option is only selectable on RGB sources. Have never been able to do anything with it on either my cable box input or bluray input.
Supposedly you can change the model number in the service menu to a d560 and enable Cinema Smooth but have never been able to get this to work I only see D530 and one other option.
post #29 of 48
I have PS51D530 (european version) and I indeed have Cinema Smooth option if I set my PC HDMI out to 1080p/23hz (23.976hz).
I'd like to see new firmwares for this set. Black levels are somewhat grey.
post #30 of 48
Originally Posted by DaveyJC View Post
1007.2
Has anyone in the US tried this firmware update on their set? I'm tempted but haven't done it yet.
