AVS › AVS Forum › Audio › CD Players & Dedicated Music Transports › Pioneer PD-M435 CD Player Help!
post #1 of 3
Pioneer PD-M435 CD Player, 6 disc cartridge changer problem, hope you experts can offer some advice.
Insert loaded cartridge with 6 (or fewer) discs, player cycles through all discs without stoping or loading any. I've tried other cartridges with same result.
Any clues as to what is going on here?
Thanks in advance,
Ron
post #2 of 3
I have the same problem,did you find any solution yet? Thanks
post #3 of 3
I have the same issue with the discs dont read and just move to next disc
any thoughts
