Sorry if already asked, just wanted a quick yes or no, will do further research.
Thinking of getting a 3D capable TV (ie, Samsung 8000 series LED, or Mitsubishi Laservue) for HTPC, and will prob build my own HTPC. The TV/HTPC will be mostly for movies, but may play some games on it not too much trouble setting up..
I know above TV's can covert conventional 2D images to 3D themselves.
Question is, how do games look on them, using the TV's 3D conversion. Are they similar to, much better, or much worse than using Nvidia 3D vision card w/ a 3D compliant HDTV (as in DLP's that accept 120Hz signal..
Also, I"m not even sure if the Laservue or Samsung 8000 series HDTV's take only the 60Hz or can take the 120Hz.
I'll keep looking, and appreciate any quick responses as well
