AVS › AVS Forum › Display Devices › Display Calibration › X-Rite's Revolutionary New Colorimeter
X-Rite's Revolutionary New Colorimeter - Page 6
post #151 of 1402
Originally Posted by ConnecTEDDD View Post
269$ Display 3 (Factory OEM Version)
+ 125$ For Adding PRO Corrections To The Factory OEM Meter.
+ 200$ For ChromaPure Software.
Total Cost = 594$
So 575$ Seems To Be A Good Offer.
Actually it's just $560 if you buy from AVS or CurtPalme.
post #152 of 1402
How can I buy it and save some money?
Please click on the banner for the AV Science store and buy it there. Please support the forum by buying it there rather than somewhere else.
post #153 of 1402
Does anyone know if the OEM meter will be coming with the X-Rite software as well for this price? I would like to confirm this before ordering.
post #154 of 1402
No it would not.
In the case of CalMAN, we have a PC Calibration add on if you need to calibrate the PC and create ICC profiles.
post #155 of 1402
This was putout this morning on the SpectraCal site...Hope this helps.
SpectraCal Press release about new C6 & OEM i1 Display Meters
Later
RayJr
post #156 of 1402
SpectraCal and X-Rite Announce Next Generation SpectraCal C6 Colorimeter
http://www.spectracal.com/admin/pres...olorimeter.pdf
post #157 of 1402
from SpectraCal: http://www.spectracal.com/press.aspx
the C6 can be purchased at an opening price of $595 ($695 after July 31, 2011)
This helps to confirm my good luck in purchasing ChromaPure when I did.
post #158 of 1402
Yet the regular version is only $245 and $295 after this month
post #159 of 1402
SpectraCAL C6 vs. SpectraCAL i1Display OEM Comparison
http://www.spectracal.com/admin/prod...Mi1Display.pdf
post #160 of 1402
So, how far off of "true" is the cheaper $265 version? I just bought a VT30 that I want to calibrate myself, but it will most likely be a one-and-done deal. Although I do tend to want the best of the best, that extra $300 needed to achieve it is really giving me pause, especially if a decent amount of that is going towards a case which doesn't add to my display performance at all.
post #161 of 1402
695-295 = 400 dollars
For a case and a tripod holder and some profiles?
Seriously?
post #162 of 1402
Seriously?
yeah I know what you mean
post #163 of 1402
If I just get the OEM i1Display to calibrate my plasma and LCD, will it not be my best choice?
post #164 of 1402
Actually, you may want to recalibrate every 2-3k hours; displays will drift. I first calibrated our plasma after 500 hours of use, and at 5000 hours, the grayscale had drifted a bit toward yellow. A few clicks to increase blue a bit, and all is well again.
post #165 of 1402
That meter represents a tremendous value to the home user.
The C6 is primarily aimed at Pros.
You can't get a better all around meter for less than our OEM i1Display.
post #166 of 1402
Seriously?
It also appears that you only get the 5x speed increase with the C6.
post #167 of 1402
Thanks, it just alarmed me on that comparison chart, that plasma was not checked.
post #168 of 1402
The display types that are checked are basically the display types that will have enhanced accuracy with a C6.
You can use either meter on all of those display types, but the C6 comes with more specific profiles to further enhance accuracy.
post #169 of 1402
And extra accuracy on things like white LED vs RGB LED, instead of a simple LED profile.
post #170 of 1402
What about that 5x speed claim? Does that jive with what we've read earlier in this thread?
Personally, I don't like all these colorimeter enhancements. My C5 seemed better off before I sent it in to get enhanced. So I planned to just use the Display Pro when I profile it off a spectro. Therefore, the extra tables are no incentive for me.
The only advantage then besides the case and tripod extender, which mean little to me, would be the 5x speed claim.
post #171 of 1402
Chad, just give a little time.. I just spoke to Josh and will get the answer shortly... I'll Post....
post #172 of 1402
Enhancements will vary from vendor to vendor.
The 5x speed difference is what X-Rite claims as a difference between the ColorMunki Display and i1Display Pro versions (retail and OEM) of the meter.
http://www.xrite.com/custom_page.aspx?PageID=260
This has nothing to do with vendor-specific enhancements.
post #173 of 1402
How does the $265 version compare to an DTP-94?
About 4 years ago I bought a Monaco PC kit that came with the DTP-94 to calibrate my last plasma and it's been sitting in a dark storage box this whole time. I don't know how much off-cal it is since I don't have a spectrophotometer but I'd imagine 4 years is enough to constitute a recalibration, even in low-light conditions.
At this point I'm weighing Cal software + OEM i1Display or Cal Software + DTP-94 recal charge (however much that is?).
post #174 of 1402
The stock i1 Display 3 accuracy matches that of a stock Chroma 5. However, it's much faster and can read much lower.
post #175 of 1402
the 'up to 5x faster' spec is comparing it to the Chroma 5...
from my understanding, SpectraCal's OEM i1 Display will have similar speed performance as their C6.
There is a new Bundle that includes CalMAN DIY w/Colorimeter Meter Add-on and the OEM i1 Display for $345 until the end of July, then $395.
For existing CalMAN DIY/Home users, you need the Colorimeter Add-on if you purchase the OEM i1 Display.
post #176 of 1402
http://consumer.spectracal.com/colle.../oem-i1display
Not true
post #177 of 1402
In This chart X-Rite OEM i1 Display is supported with CalMAN DIY without add-on licence according to that link.
http://consumer.spectracal.com/pages/meter-support
post #178 of 1402
Not true
this was told to me directly by Joshua Quain late this afternoon.. that "the OEM i1 Display requires the Colorimeter Add-on" ..... which is also the requirement for the Chroma 5.
I'll bring that table up immediately to Joshua and post with the appropriate correction after his reply....
post #179 of 1402
The OEM i1 Display should be better than a DTP-94 in pretty much every objective comparable, and it doesn't need dark offsets.
post #180 of 1402
How am I supposed to interpret the Plasma/CRT section of this chart by Spectracal that compares the C6 to the i1Display; particularly the lack of a check next to 'Plasma'?
