AVS › AVS Forum › Display Devices › Display Calibration › X-Rite's Revolutionary New Colorimeter
X-Rite's Revolutionary New Colorimeter - Page 3
post #61 of 1308
An increase in technology. Period.
I expressed an interest in buying a Hubble awhile back to a guy in England who is as close to X-Rite as CP, SpectraCal, etc. He said to hold off because he had a meter under a non disclosure agreement and thought I might want to be patient. He answered an email today and verified that the NDA meter is the D3. He saved me a ton if the D3 performs. We'll know soon enough.
post #62 of 1308
Toshiba 55ZL1 Direct LED-TV Auto-Calibrate System With D3
post #63 of 1308
What if this is simply the same kind of "calibration" that the SpyderTV does, with adjustments done directly to the set via DDC? Then it's no bargain at all, IMHO.
EDIT: It appears that the calibration is more in-depth, with grayscale, gamut, and gamma parameters checked and adjusted. But it also appears that the unit is meant to work with certain high-end Toshiba sets that feature a particular 3D LUT containing reference standards that the TV checks the meter's readings against and then develops corrections so the set's output matches those standards. See here:
http://eu.press.toshiba.eu/en/downlo...pril_2011.pdf?
post #64 of 1308
I`m a noob to chromapure, i`m sure the software is excellent; however i`d like to know if x-rite have improved their software for the i1 display 3.
If chromapure can access all the hidden features of colormunkie turning it into a i1 display 3 then it makes sense to get the colormunkie and chromapure as it alot more affordable.
My questions are:
does chromapure turn the colormunkie 5x faster?
Can chromapure with colormunkie enable White Point, & white luminanc to Custom or Measured?
Can chrompure enable colormunkie display 3 for tone respnse (1.8, 2.2, 3.0, sRGB)
I really want to buy one in the next few days so my choices are i1pro display 3 without chromapure or i could get colormunkie display 3 with chromapure standard.
post #65 of 1308
I think it just might possibly be the first consumer TV with internal 3D LUT hardware ---- check this out:
http://thegadgetsite.com/2011/04/tos...l-recognition/
post #66 of 1308
looked at other info - incomplete, more than likely 2D with a limited number of color points.
post #67 of 1308
post #68 of 1308
These features differencies are only available using Xrite iProfiler Software included with the meters.
ChromaPure has not that software limits, its operating the meters using 100% of each meter features.
post #69 of 1308
Chroma 5 costs about 500-600$ in retail but it was an OEM X-rite meter. If it was available as a retail then its price i think should be around 1000$.
Many companies used that Chroma 5 OEM meter with another name as Progressive Labs C-5, Sencore CP6000 ColorPro with increased price also.
How is possible now a so lower cost Retail Device (D3) of the same company, which is Retail Product, can outperform a More expensive OEM product and also have similar reading speed & low light reading as X-Rite Hubble (3400$), outperforms some times the color accurancy of Xrite i1PRO (900$),
With Only 269$?
IMHO, trickle down technology from high end units (like the Hubble) and marketing it as a consumer device where the manufacturing volumes will be hundreds of times higher is certainly helping keep the price low.
What suprises me to some degree is HOW low they've priced it. They could have doubled the MSRP and it would have still sold well in certain market segments like A/V and Home Theater. Not so much for the PC/Mac monitor and photography crowd probably though.
Kal
post #70 of 1308
Trying to find official announcement from X-Rite. Can't seem to find formal announcement.
post #71 of 1308
http://www.xritephoto.com/ph_product...w.aspx?id=1454
post #72 of 1308
Please no sales links. Reminder Ebay is not allowed. Thanks for your cooperation and understanding!
post #73 of 1308
Wasn't eBay. Just Google.
post #74 of 1308
Will this unit work with front projectors. I just have a front projector and have no use for other applications. I also just have Calman 4.2. I don't really have the need to upgrade that either. Spectracal made it sound like it would not. They are having a special edition made for them with enhanced tables. Their unit will be called a Chroma 6 and retail for approximately the same amount as a current Chroma 5.
post #75 of 1308
Do you have a web link?
post #76 of 1308
Absolutely. Both off the screen and off the lens.
Edit: no comment on the pricing except to say that what you suggest is too high.
post #77 of 1308
I hope a stock unit will work with CM.
post #78 of 1308
ChromaPure Standard comes with support for one meter included in the purchase price. Support for each additional meter is $100.
ChromaPure Professional supports an unlimited number of meters. To add a meter, simply contact ChromaPure and they will update your license free of charge.
post #79 of 1308
If I was to buy ChromaPure for $180 (don't currently have it) and buy the ColorMunki Display for $189 elsewhere, could I still have the PRO upgrade done on it for an additional $125? Is there any hardware advantage to getting the i1Display Pro instead?
post #80 of 1308
Greetings:
I decided to buy the Display Pro 3 and use the included software to calibrate
my new Panasonic (TC-P55VT30).
Would you guys thing I'll be out of my depth! and basically it is a waste of time
going it alone this way?!
Or I should bite the bullet and get a package with Calman or Chromapure?
Would appreciate any input.
post #81 of 1308
Originally Posted by johnteeee View Post
Greetings:
The included software is generally aimed at PC displays, not TV displays.
CALMAN or ChromaPure are aimed at TV displays and projectors.
post #82 of 1308
If your using your TV as your PC monitor its should be ok.
I`d be curious to know how the x-rite software performs without chromapure, as the new i1 display 3 must have had a major software rewrite to match the new hardware.
+ i heard theres extra options for new generation displays such as LED + newer projectors etc
post #83 of 1308
So can I stick with this meter and just purchase the software from one of them?
Assuming one of them will support this meter in near future.
Thank you
post #84 of 1308
Thank you
Chromapure is already supporting it.
post #85 of 1308
I am curious about this too, if they come with some calibration software for TVs and PJs.
post #86 of 1308
Thanks Ranger.
So I could purchase the meter from the manufacturer and just opt for Chromapure software only.
Right?!!
post #87 of 1308
Thanks Ranger.
Right?!!
ChromaPure:
Adding Additional Meter or Signal Generator Support
ChromaPure Standard comes with support for one meter included in the purchase price. Support for each additional meter is $100. You may also purchase ChromaPure Plus, which adds support for the AccuPel family of video test pattern generators. ChromaPure Professional includes support for unlimited meters and all of the supported test pattern generators.
post #88 of 1308
Right?!!
Yep.
post #89 of 1308
Where would the "pre-order" be under?
Thank you
post #90 of 1308
The new Sony 30ES front projector boasts new calibration controls:
"The VPL-HW30ES offers Real Color Processing Version 2" function to adjust the colour and hue of each target colour of the projected picture independently.
Additionally, version 2 adds the ability to adjust the brightness at the same time. With this capability, dealer and enthusiastic users can tweak the images to perfection."
Can this new meter and software be just the hot-ticket to adjust each target color, tint and now brightness? Or will there need to be an update?
