AVS › AVS Forum › Audio › Receivers, Amps, and Processors › First AV Reciever!! Onkyo TX-NR609 or TX-NR708?
post #1 of 5
Hey guys,
I am looking to buy my first home theatre set up and am torn between the Onkyo TX-NR609 and TX-NR708....
Being a complete novice when it comes to all this, and after reading all other threads/posts on others asking the same question, I'm still at a loss as to which will suit me better.
I work for an electronics store and am able to purchase the TX-NR609 at cost and the TX-NR708 at 10% below cost, which will still be $150NZD more expensive. Is what the TX-NR708 offers worth the extra cost? I'm not too sure if the Audyssey 2EQ vs. Audyssey MultiEQ debate will apply or not as I have never used this.
I will be using either the Kef KHT2005.3 speaker package...
www .kef.com/gb/SurroundSound/kht/2000
Or the Jensen XR series...
www .jensenspeakers.com.au/page/shop/browse/a/category/e/products_xrseries
(sorry about the broken links, I'm only new to this site and it automatically won't let me post URL's in case I'm a spammer ha)
Please help!
post #2 of 5
Both are a good choice I believe so eighter will work out just fine for the set up you have listed. Its up to you and your pocket book thou,Just me... I would choose the 708 as it has the Muliti EQ.
post #3 of 5
you may consider the rc370 as well.. it has just a couple less features than the 708 at about $100 US less
post #4 of 5
Am I likely to use the Audyssey technology though? I have never had an amp before so do not know how easy/hard it is to use or to get right. And apart from the MultiEQ, is there anything else which seperates the 609 or 708 apart from the upscaling?
post #5 of 5
Had a quick look at it online and it seems like an impressive amp for the cost, but it isn't an amp I can get a hold of through where I work, which means I'd be paying quite a bit extra to buy from another retailer. The only other amp that we have that I have been tempted by is the Yamaha RXV667, being around the same price bracket for what I can afford.
