AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Would the Brookstone Outdoor Weather Resistant Speaker work with my system?
post #1 of 2
All,
I was thinking about purchasing the Brookstone Outdoor Weather Resistant speaker for my balcony. My main reasoning is that I have a small balcony for my apartment and would like to be able to listen to the TV & Ipod sound outdoors without blasting my indoor speakers. I can't set up any type of crazy outdoor set up that is synced with my Home theater system so I figured this would be a quick fix to get what I need.
However, I am not sure if I can set this up so the TV/Ipod sound comes out of all my speakers (7.1 system) AND still gets transmitted to the outdoor speaker. Could someone please advise if what I am talking about is feasible with my Surround Sound set-up (Onkyo 7300 HTIB) and the Brookstone speaker? Links to both products are below with a set up link for the HTIB.
http://filedepot.onkyousa.com/Files/...42560356e10543
http://www.us.onkyo.com/model.cfm?m=...ss=Systems&p=d
http://www.brookstone.com/indoor-out...-speakers.html
Any advice would be greatly appreciated.
MPHD
post #2 of 2
Yes, it would appear the Brookstone wireless speaker would work by connecting the transmitter to the Zone 2 preout jacks on the back panel of the Onkyo. You'll have to connect an analog cable from each source you want to pass to Zone 2 in addition to the HDMI cable you are likely using for the main zone.
