The geometry on my display is really bad. It's easily noticible for example by looking at the display in "normal" mode (with the grey bars on the side. The picture is bowed.
I found some ADDR settings on Keohi HDTV to reset the convergence to factory defaults, but that didn't seem to help.
Is there a way to set the geometry to factory defaults in the ADDR menu?
My understanding was that resetting the convergence (there were 6 settings, RGB*HV) would fix the geometry.
I have tried to correct it as best I can manually in the service menu, but I can only do so much. I checked around and the overlay grids cost around $300! Ouch.
Am I just SOL?
Am I just SOL?
