My ES15 allows me to press record and start recording right away and you can keep pressing record again for raising the recording time to 30mins, 1hr, 1.5hr, 2hrs etc. But I want to make it stop after 24 mins. I don't know how to do that. If I choose FR then it allows me to set recording time - but to keep recording quality the same, say at SP level, I have to select 2 hours in FR for the first program but stop it at 24 mins, then choose 1:36 for the second, 1:12 for the third etc and I can make it work that way. The down side is it requires two steps - start and stop. I want to avoid the stop part and let the recorder stop automatically. Is there a way to do this? The only other option is scheduled recording for the tuner which I am not doing
AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › panasonic ES15 choosing recording times in line recording
AVS Top Picks
post #2 of 7
6/22/11 at 10:25am
post #3 of 7
6/22/11 at 10:46am
post #4 of 7
6/22/11 at 1:50pm
post #6 of 7
6/23/11 at 11:11am
AVS Top Picks
