I used to think sky in the uk had by far the best picture and spec in the world, until I saw some of the quality wowwow put out!
Is anyone broadcasting 1080p in any codec yet?
Is anyone broadcasting 1080p in any codec yet? |
| Who has the best technical standard worldwide? |
of degradation in image quality after cascaded codes connections, that's why they're using 4:2:2, large bandwidth feeds, and contribution encoders.
coming and say that some distribution encoder suppose to have some mambo jumbo capabilities but, from what I've seen, even the best (arguably) contribution encoder can't go below 10 Mbps (in H.264/4:2:0/8 bit/D) and still show some reasonable images. Not mentioning that you hit water (sort of speakin') it's bye bye
I am shocked that with a little pc know how they end up looking better than some bluray's
120Hz will be interesting in 50Hz land - but 300Hz was never really going to fly, and wouldn't have been great for 24Hz sources.
600Hz anyone... ![]() |
Yes, I think they should use 600 Hz
![]() But even that would be a problem because they use 59.94Hz and 50.0 Hz so they'd need to do speed-up of 59.94 Hz content (or pull-down for live content) if the TV was 600.0 Hz. And if the TV was 599.4 Hz, 50Hz content would need pull-down. And we still wouldn't be able to watch The Hobbit films (around 48 fps) properly (without pull-down conversions) . |
| Yes 120Hz will be a problem for 50Hz shooting and content. They should allow more than one format in the standard. |
100 frames/fields per second is the minimum frame rate for sports television. Of course, more is better, if you can take the hit in sensitivity.
I still laugh when people say that progressive 50p or 60p is "better for sports" than the comparable interlaced frame rate. A motion-blurred image is still blurry regardless of whether it is 1280x720 or 1920x540. |
