I'm trying to work out the best replacement for 2x MK MX350 Subwoofers.
My knowledge is a bit out of date because I've not really took too much notice of any other Subwoofers for around 6 years, as I've always had 2x MX350's in my room. After looking at a few options recently, I'm currently considering a Sub15.
I should point out that a single MX350 is actually more that enough to fill my room. I had a few reasons to go for 2 of them, but they aren't relevant to the point of the thread, so I won't go into them.
I'm looking for clean, fast, tight, punchy, etc etc bass (aren't we all) that goes as deep as possible but also performs well in the upper frequencies. As my room is fairly small I don't think volume will be an issue. I'm also trying to keep things sensible (in both size and price) which is why the Sub15 is the main contender right now.
So with all that in mind, my questions are:
Can a Subwoofer be too big for a room? Especially when using decent room EQ technology.
Would there be any benefit to me considering 2x Sub12's over a Sub15? Remembering that it's in a relatively small room and I'm not needing high SPL's.
Can anyone comment on the performance difference between an MK MX350 and the Paradigm Sub15?
), but even with the same size amp with a larger box and woofer diameter it's tough to say that the SB13 would be cleaner?
I think it would probably be sidestep though, in my room anyway.
