I'm in the process of finishing my basement and I've decided to add a budget 'cinema' to the mix and I have a few questions before the drywall goes up. My apologies in advance, I am very new at this.
I've already had my electrician wire power outlets to where I plan for my projector mount and to where I plan to have an electric screen but I'm somewhat lost on what I should be doing for HDMI/Component wiring.
I want to make sure I do this right the first time so I'm not backtracking as I decide to uprade equipment. If it makes a difference, my initial equipment consists of a BenQ w600+ projector, an LG 5.1 HTIB with built in blu-ray, and a 100" electric screen. We will be using it for movies and occasional TV use.
So here are my questions/concerns:
1) Do I just need an HDMI cable running from the projector to the LG system or should I also run a component cable, VGA cable, or an additional HDMI cable?
2) I obviously want the audio to play from the surround and not the projector, will there be an issue accomplishing this connecting with HDMI? As the LG system is both the reciever and blu-ray, will plugging in the HDMI somehow 'trump' the blu-ray audio and send it to the projector built in speakers? Is there a special HDMI cable I would need for just transmitting video?
3) Is there a problem with long-run HDMI cables (~20ft), is there anything I should be looking for in particular?
If there is anything else you think I'm missing, I would really appreciate a heads up. Thanks
Jay
Jay
