AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic ST30 series Media Player
post #1 of 2
I just had my 60ST30 delivered and it's great. I've been trying to get various video files to play through the Media player by way of a thumb drive. I've only had success with some .mkv files. I've tried various files with no luck. I've tried creating my own .mkv files with no luck. I believe there is an issue with the audio track but I can't figure out the right configuration. Has anyone had success with playing video through the media player? If so, what is the file format?
Thanks in advance...
post #2 of 2
Yeah I have the same problem too.. I've had the 42st30 for a couple of weeks now and I hate how glithcy the software can be... The video format that worked for me was mp4 with video codec h264/avc and audio codec mpeg2/4. i used avs video converter. it pretty easy to use and i could set up the format settings easily. im trying to figure out 3d formatting as well, but it might take a couple of days...i'll post an update when i get a chance to figure it out
