I need some advice on this one. Rather than spend more on the "official" adapter, I'd rather buy an inexpensive WAP to use as my situation is temporary.
Wiring it directly to the router is not an option, as it's too far and not under my control anyway.
The router is a Linksys WRT110 N Router. The issue I've found is some reviews for different access points say "Oh this won't work with the 360" etc. so it throws me off.
Does anyone know of a WAP (Or cheap router that can be configured to use as an AP) that will absolutely work on an N network with the 360?
