Manamb >>> How exactly did you arrive to the conclusion that according to those numbers the NEC comes second to the Acer for HT applications ?
The NEC has higher FO/FO contrast and ANSI lumen output, whereas the Acer has higher ANSI contrast; Colors from both pjs should look similar onscreen, however the reviewer did point out the excellence of colors from the NEC.
From my point of view, the NEC slightly edges out the Acer pj performancewise, keeping in mind the fact that it appears to run somewhat hotter than the Acer and has a msrp of $800 vs. $700.
BTW guys, i downloaded the NEC L50W product sheet from the company's website and when i noticed the spec for "contrast ratio 2.500:1" i had to smirk and think how refreshing, for a change, to see a spec that is actually too conservative according to an external test reporting of the product ?
Hopefully these pjs would meet and exceed our expectations!
