Hi everyone,
Recently, I have developed an interest for understanding the theoretical difference between e.g. 2.0 and 3.1 audio setups. Since I am somewhat a newbie when it comes to this audio stuff, i would like to ask you what should the decision criteria be for deciding which one is better for me (assuming I have a fixed amount of money to use).
Here is some background for my quest: I currently have a pair of Q Acoustics 1030i fronts with Onkyo 508 av receiver. I have been considering of using about $1,500 to upgrade the system to 2.1 or 3.0. But then, I started to consider whether I should just buy better fronts and stay with 2.0 for the time being. My usage is 70% music and 30% movies. So I am not really looking for suggestions on particular speakers I should buy, but rather I aim to understand what is the audio theory behind the choice whatever it should be.
I have understood that very often the bass is actually the most difficult to play correctly for any speaker and good fronts typically have used lot of the extra money to improve their bass response (is this correct?). So if I add an subwoofer for my system does it mean that the extra money spent for better fronts is useless? And in general which one is better (or what is the difference; assuming that the money used is the same):
1. A good subwoofer with mediocre fronts, or
2. Good fronts (which can also handle the bass well).
(i.e. what is the trade-off between acquiring sobwoofer vs. buying better fronts)
In addition, if I - supposedly - buy a decent subwoofer (e.g. around $1,000-1,500), should I always set the fronts to small to let the subwoofer play all bass frequencies or what is the optimal setup? I understand this may depend on the quality of the fronts, but in that case, how good should the fronts be in order it to be advantageous to set them large (and how does the audio theory go)?
So putting it simple: if I have e.g. $2,000-2,500 to use, what is the decision criteria in choosing between using the money for 2.0 system vs. 3.1 setup (which one is better for what)?
. That was my only contention.
