@arnyk:
I'm currently on vacation so I only have my phone, and thus I'll perhaps be a bit short in my answer. Anyways..
Sure, my post was provocative, speculative and deliberately so, but perhaps not a post that I am particularly proud of (I actually think B&C makes good products for what they are meant for). Nevertheless, I know a thing or two about driver design -perhaps a little more than many here (still, there are many that know more, for sure).
As you say, pro grade drivers are designed with a different set of objectives than "consumer" drivers. High efficiency, durability and high SPL are some of them. But, as you know, designing a driver (or a speaker) you are basically facing a number of conflicting parameters to "optimize". If you optimize on one parameter you'll be forced to make sacrifices in other areas. It is an excersize in making the right sacrifices for the application.
In this particular case, ruler flat on-axis response and very low distortion was put forward as absolutely essential. A property, the B&C coax does not excell at. If that's the only criteria there are other alternatives that are way smooter and better behaved - coax drivers as well as parrallax combos that produce lower distortion and at the same time a flatter on-axis response. Naturally, these have other drawbacks that you as a designer needs to address to find the best compromise (like most likely less efficiency and/or max SPL).
How can you control vertical dispersion, doppler distortion, phase integration, dispersion, impedance, linear excursion etc etc etc. What is most important, what set of parameters will get you the closest to the "ideal" for the application you are targetting?
