Originally Posted by ZSK
I'm really thinking about buying the Acer K330 to replace a Mitsubishi HC1500. I like the idea of LEDs and not worrying about bulb life, just not sure I will be happy with the light output. But I do have a light controlled basement with no windows... pitch black when I'm using the projector. Any thoughts? The main use will be Xbox 360 gaming, on a 100" matte screen.
Thank you!
Thank you!
Hi ZSK, I can't say how it would compare to the HC1500 as I've never seen it but my guess is if it is pitch black, even 100" would be absolutely fine. I've been playing xbox at somewhere around 80"-90" and even ok with light on. I thought it looked great with no lights on. Again I really can't compare to bulb projector as I've never used one but I have heard the perceived brightness from LED is better than bulb when comparing same lumen ratings.. I was personally surprised at the brightness that came out of that little thing..
