Originally Posted by
3DNewb
Awesome, I hope it turns out to be a better PJ for you. If you would, please post pics as well as mention any type of focus or CA (chromatic aberration) issues that you encounter.
Also, do you plan on using the 3D feature at all? If so could you varify that 1280x720P@120Hz is supported? If not could you use Monitor Asset Manager to retreive the EDID information and list the 120Hz supported timings?
Free download here
http://www.entechtaiwan.com/util/moninfo.shtm
Ty in advance
Monitor Asset Manager Report, generated 10/29/2011
Copyright (c) 1995-2011, EnTech Taiwan.
Monitor #1 [Real-time 0x0021]
Model name............... PLED-W500
Manufacturer............. ViewSonic
Plug and Play ID......... VSCF428
Serial number............ SL1113500097
Manufacture date......... 2011, ISO week 35
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. Undefined or variable
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Supported
MCCS revison............. 2.0
Display technology....... Not specified
Controller............... Genesis 0x21
Firmware revision........ 1.2
Firmware flags........... 0x0000FFFF
Active power on time..... Not supported
Power consumption........ Not supported
Current frequency........ 16744.19kHz, 222.74Hz
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.670 - Ry 0.330
Green chromaticity....... Gx 0.210 - Gy 0.710
Blue chromaticity........ Bx 0.140 - By 0.080
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-100kHz
Vertical scan range...... 50-120Hz
Video bandwidth.......... 150MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1280x800p at 60Hz
Modeline............... "1280x800" 83.500 1280 1352 1480 1680 800 803 809 831 -hsync -vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
1680 x 1050p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
640 x 480p at 120Hz - VESA STD
1280 x 720p at 60Hz - VESA STD
1024 x 768p at 120Hz - VESA STD
800 x 600p at 120Hz - VESA STD
1280 x 960p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 2
Detailed timing #1....... 1280x720p at 60Hz
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #2....... 1280x720p at 50Hz
Modeline............... "1280x720" 74.250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
Detailed timing #3....... 1920x1080i at 60Hz
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #4....... 720x480p at 60Hz
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 +hsync +vsync
Detailed timing #5....... 1920x1080p at 60Hz
Modeline............... "1920x1080" 148.500 1920 2000 2044 2200 1080 1084 1089 1125 +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
720 x 576i at 50Hz - Doublescan (4:3, 16:15)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
1280 x 720p at 60Hz - HDTV (16:9, 1:1) [Native]
1280 x 720p at 50Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
640 x 480p at 60Hz - Default (4:3, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.0.0.0
Supports AI (ACP, ISRC).. No
Supports 48bpp........... No
Supports 36bpp........... Yes
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
Maximum TMDS clock....... 225MHz
Report information
Date generated........... 10/29/2011
Software revision........ 2.60.0.972
Data source.............. Real-time 0x0021
Operating system......... 6.1.7601.2.Service Pack 1
