AVS › AVS Forum › Video Components › Home Theater Computers › HTPC build with Windows XP Professional
post #1 of 4
I am in the process of researching components for a HTPC using a Core i3 processor and wanted to know if Windows XP professional is an acceptable operating system to use or do I need to get Windows 7. Hate to spend an extra $100 when I have a copy of XP professional already. All help is appreciated.
post #2 of 4
Acceptable, yeah sure. You just don't have the option of using Windows Media Center but there are a number of front-ends/10' UI you can use such as XBMC, Media Portal, N-PVR, etc.
post #3 of 4
Thank you very much. I was thinking of using XBMC Live. Any feedback on that?
post #4 of 4
XBMC does not support recording or viewing live tv. You would have to use NPVR for that.
