AVS › AVS Forum › Audio › DIY Speakers and Subs › question about speaker wire? positive, negative?
post #1 of 18
i just got a roll of speaker wire, and this will be my first time using banana plugs.
the color of the speaker wire is copper color for both wires. on the plastic covering, one wire has a blue stripe and the other plastic cover has no lines.
is the one with the blue line the negative wire?
thanks, sorry for the noob question.
post #2 of 18
Physically, there's no difference between the wires. I don't know if there is a standard convention for it. The important thing is to be consistent. Whether you make the stripe positive or negative doesn't matter as long as you stick to it and make all the cables the same way. I'm sure someone more experienced will chime in soon with details about whether or not there is a convention for it (for anyone not familiar with "convention" in this context, it means an arbitrarily chosen method of differentiating between things. For instance, positive always being the red wire is a convention. There's no reason that the positive wire needs to be red, but we make it that way so it is easier for everyone to keep track of.)
post #3 of 18
ok cool. thanks for the quick reply sproulle, i appreciate it.
post #4 of 18
Just start your own 'convention'. Use the striped conductor for ALL positive (my own choice) or ALL negative and you'll be fine.
post #5 of 18
I had the choice of either expensive red/black jacketed wire or the same diameter wire in plain white for both wires.
The solution to what of the two white wires was positive was this:
Hookup the wire ends to a speaker and grab the ends of the wires(mine had a tiny bump along one of the close to identical white wires).
Grab a AAA or AA or C or D or nive volt batt. and notice one terminal has + and the other batt. terminal has -.
Ok now when the speaker cone pushes OUT or towards you thats when you have the + batt terminal sending juice to the + speaker terminal and the - batt. terminal sending juice to the - speaker terminal.
Once you have all the speakers hooked up make sure all the cones push out/towards you.
post #6 of 18
^^^ Huh? He already has cable with one conductor marked with a blue stripe. There is no need for that.
post #7 of 18
Really?
I once purchased some woofers that had + and - markings on all of them.
But the bass sounded off! when I was playing the four woofers and feeding them DJ Billy E songs.
I had a look and every RED + wire running from the RED+ amp terminal was going to a RED + woofer terminal and every amp terminal BLACK - was going to a BLACK- on the woofer.
Everything hooked up properly?
Everything red going to red and everything black going to black?
Everything in phase? right?. right?, right!!!??
Hell no!!
It was WRONG!! to ASSUME!!
The problem??
Some wonky fried worker at the woofer factory placed a big RED + on the woofer NEGATIVE terminal and that same idiot! worker placed a big BLACK - on the woofer POSITIVE terminal!
Morale:
Always! test! your woofer phase!
post #8 of 18
Don't buy crap. I've never had something wired incorrect from the factory yet.
And if you have an issue, fix it then.
post #9 of 18
I do not buy crap.
But since products are made by the hand of man and not God then its my rule of thumb to never blindly trust what a machine says without checking it.
In other words trust but verify.
post #10 of 18
post #11 of 18
I have used the blue striped wire as positive for over 30 years.
post #12 of 18
If you look closely at the insulation of the solid white wire, you will see that one wire will have more ridges or groves in the insulation. That way you can identify and maintain polarity. Every piece of two conductor lamp cord that I have seen is marked this way regardless of color.
post #13 of 18
Or sometimes the two conductor lamp wire has letters on it.
So far I have had drivers with inverted polarity from Boston Acoustics, Infinity, Cerwin Vega???
So for me its the same as a conversation I had with a State Trooper when I stopped and I noticed the troopers car behind me I went huh??
But no prob. the trooper just wanted to ask why I had the habit of tapping my brakes/slowing down at intersections when the light is green.
The green light means nothing to a drunk that tbones my ride, right??
The trooper said avoiding dirt status.
I said dirt status??
The trooper said DRT as in dead, right, there.
Well a black or red on a speaker means the same to me.
What counts is if all the cones move in harmony then its ok.
post #14 of 18
^^^ wtf are you smoking. We're talking about speaker wires with labeling along the whole wire. Theres no issue with polarities here and telling him to do a 9 volt battery test is a waste of his time.
post #15 of 18
You are right.
A nine volt batt. test is a waste of time..............for pros.
Noobs however install when tired/ drunk/smoked and woofer cones end up punctured, wires connected whatever, etc.
My fav. is seeing noobs use a drill with a philips bit to install woofers as theres a 50 % chance that a woofer is going to be punctured when being drillstalled.
My noob fav. so far is being asked why a car amp will not turn on when the noob had a good positive connection and a good ground connection.
Had a look at the car and yep it had a good ground..........LOL!!
Two straps were holding a shiny aluminium beercan to the side of the vehicle and the inside of the can was filled with dirt and the black(ground) cable was placed firmly in the dirt inside the can for a ""good ground"" LOL!!
Removed can and drilled three holes in chassis then used three bolts to hold ground cable firmly in place on shiny chassis metal.
Hifonics car amp works to this day in noobs car.
post #16 of 18
^^ Strawman.
post #17 of 18
^^ Strawman.
Ok I give up since you seem to think that no one, ever feels the need for testing speaker polarity since that one wire is marked and testing is a waste of time??
I guess one wire is blue works for the entire world???
http://www.mcmelectronics.com/produc...LAID=546659236
http://www.hifisoundconnection.com/S...GoogleBaseFeed
http://www.phase-it.com/
post #18 of 18
Unless the guy is going to plug one wire in one ear and another wire in another ear then those wires are going to be hooked up to a speaker.
Blindly trusting that the red on a speaker actually means + without a verification test is naive.
Thats what I am talking about.
