Another DownUnder theatre - Page 7
post #181 of 424
Riser is framed, insulated, first layer of ply finished, second layer of ply + GG on going ...
Cheers,
post #182 of 424
Thats an awesome space but have you got windows all round?
post #183 of 424
The windows will be permanently closed off. We put them in for external appearance, future use, resale etc. There are also BCA / Occ Cert issues as well.
Cheers,
post #184 of 424
Ok, makes sense. Was just trying to figure out where you where going to put stuff lol. I bricked mine up ; )
post #185 of 424
Four of six windows plugged, baffle wall framed, screen wall framed, equipment room framed, one of the doors in ...
Oh ... and Gerben from Procella has been around for a look and given it all the official seal of approval !!
Cheers,
post #186 of 424
Those doors are ridiculous!.....in a good way
post #187 of 424
Hi Peter,
Yes ... if you look closely at the bottom of the door you'll see two black dots ... they are the buttons for the twin (!) drop down seals. There are also additional seals to be added inside the steel frame to the jambs and head. You can also just see the gap between the two steel frames ... one attached to the garage / theatre and the other to the house.
Cheers,
post #188 of 424
Great photos Peter. Those doors are engineered and built like a tank. Coming along real well. Won't be too long now. If you need a hand with anything, please yell out.
Cheers
Greg.
post #189 of 424
How does the drop-down door seal work & where do you get them? I have about a half inch gap under mine... Inkeeping with the aussie theme, I posted some gardening photos
post #190 of 424
I suggest you look for a local door specialist ... search for fire and acoustic doors ... and they should be able to advise. My drop down seals are rebated into the bottom of the door, but they can also be attached to the face of the door.
Here's a mob that a quick search turned up and they just happen to be up your way ... Door Seals
Cheers,
post #191 of 424
Peter,
Just stumbled on your build site. AWESOME! I'm keeping up with this one. Thanks for sharing the details and process.
post #192 of 424
This is fantastic! So good to see fellow Aussies doing this. I'm hoping to join the club one day as well... on a slightly smaller scale though.
Still - subscribed, looking forward to more updates!
post #193 of 424
Hi toonz,
Where are you ?
Cheers,
post #194 of 424
Cheers,
Thanks, I'll take a gander if it becomes necessary. We have an office to walk through with a sliding door then the solid door to the media room so I'll only know how much sound is going to leak upstairs when I fire it all up.
post #195 of 424
Hi toonz,
Where are you ?
Cheers,
I'm in Canberra. Almost finished building our new house, which will have a general tv room that I'm hoping to get a projector setup in. Won't be anything to this scale... but still can't wait!
post #196 of 424
Baffle wall is sheeted, equipment room is partially sheeted, soffits are framed and nearly fully sheeted, ceiling baffle framing is started ...
Very happy with the progress !
Cheers,
post #197 of 424
Whats going in the ceiling baffle? thats huge/deep
post #198 of 424
Hi Peter,
Overall the baffle is about 300mm deep. The face is 50 x 25mm slats with 15mm gaps between them, running across the room. Above that is 150mm thick rockwool with air above that.
It's good having a 3500mm high ceiling, as even with the riser and ceiling baffle I'm left with 2900mm clear.
Cheers,
post #199 of 424
Uber bass trapping.....nice!
I'll have to pop down some time and check it out (I love seeing houses in progress...I guess its nearly finished inside though?)
post #200 of 424
Hahaha, thats friggin hardcore dude, hardcore
post #201 of 424
I have nothing more to add. I can't compete with those baffles! I'm just going to cry myself to sleep in my low ceilinged pokey theatre!
post #202 of 424
That is one seriously large room, should sound fantastic.
post #203 of 424
Hi Peter,
Yeah ... the inside is nearly finished or they wouldn't have started on the theatre. The kitchen is really the only significant thing left, and it should start going in this week.
You're welcome to come for a visit any weekend. We're renting really close so it's easy for us to get there any time.
Cheers,
post #204 of 424
Originally Posted by dingaling2004 View Post
i have nothing more to add. I can't compete with those baffles! I'm just going to cry myself to sleep in my low ceilinged pokey theatre!
lol !!
post #205 of 424
Almost had a tear come to my eye......too funny.
post #206 of 424
Bass absorber baffle is finished, soffits finished, ceiling baffle insulated, downlight wiring done, speaker wire in, column framing underway, one speaker hole cut in baffle wall ...
Cheers,
post #207 of 424
Nice Progress!!!!
So are you building window plugs or using gyprock over them?
I am still wondering about "plugging," my window but not sure what that will achieve other than light.
post #208 of 424
The window plugs are two layers of 15mm MDF with GG. No doubt I'm losing some isolation this way, but I really had no choice with the other constraints we faced.
Cheers,
post #209 of 424
Ah ok Thanks. I think I will just have to use a thick curtain for my application. I have a 3.6 width x 1.25m tall window. I have 2 other openings as well and I am just trying to do the best I can with what I have.
I was trying to talk the wifey into letting me have all the new shed space for my HT room which would have been 7x5m. That was a no go. LOL
post #210 of 424
Hi there David,
That's a fairly large window. Obviously the thick curtains will give you good light control but probably won't do wonders for your isolation efforts... Particularly the lower frequencies. My two front windows were a similar size and prior to building the room, my 2.1 system was loud at street level, about 80 feet away. Now all the neighbors can hear are my rattling gutters and the occasional nail shaking loose and falling on the ground If you want to scare the wife into letting you have the larger space, set up your gear and subs and let her hear it. You'll be in the other room before you can say 'emotional manipulation'. good luck. If that fails, diamonds seem to be a good temporary fix!
Oh, and looking great Peter. Your progress is getting faster! And looking really good too. Must be happy with what the builder is doing.
