Hi Peter,
If you go back up to my sketchup views you'll see the layout for the panels, although it's a bit hard to pick up at this size. They are typically from column to column (1.5 - 1.8m) and 600mm high.
I'm still a little conflicted on the screen wall. The room will be used for a lot of music listening so I'm trying to avoid making it too grim. The masking system I'm getting from Chris Young in Melb has a reasonably wide perimeter frame which is covered in black velvet.
I may well try the Cobalt and if I'm not happy it's not a huge task to change the fabric.
Cheers,
Cheers,
