AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Sub for 3.1 Rock Solids
post #1 of 2
I am considering using 3- B & W Rock Solid speakers/monitors for a 3+1 flat screen sound system. I have the Solids, and need Sub and Receiver advice.
What do you think of using a Lava LSP 12 or a BIC PL-200 for the sub? (14 x 20 room, TV seating at 10 feet off 14' wall).
Also, any recommendations for an inexpensive receiver (Under $250)
I am trying to avoid buying the Bose Cinemate II system my wife wants.
Thanks for your thoughts!!
post #2 of 2
If the primary is for HT then I would suggest the Pl-200 as its an excellent performar for HT with a low cost. I have two in my HT area and am very happy with them... esp for the price of $270. If anything thou, when it comes to music they to lack a bit in that department, not bad by no means but if anything that would be the Pl weekness.
Lava seems to have a good rep as they offer a 30day money back if you dont like it so that may be worth a shot as well. You may have to do a little research yourself on the Lavas... but IMO I think are a soild choice for the budget area as well.
As far as receivers go, I would look into what fits your needs the best such as inputs/out's, hdmi's and such.
Heres just a few to look at; *(in the $250 range as requested)
http://www.amazon.com/Pioneer-VSX-82...438842&sr=1-13
http://www.amazon.com/Pioneer-VSX-52...9438842&sr=1-4
http://www.amazon.com/Denon-AVR-1611...439372&sr=1-30
http://www.amazon.com/Pioneer-VSX-92...439421&sr=1-28
*If you dont mind a fact. rerb unit, take a look at this as its a good deal!
http://www.vanns.com/shop/servlet/it.../onkyo-txsr608
Anyhow, I just thought I would throw a few ideas around for you. Have a great day!
