Hey,
So I bought the Denon DHT-591BA 5.1 Home Theater System, which comes with the Denon AVR-591 receiver and a set up of 4 Boston Acoustics surround/bookshelf speakers,1 center channel speaker, and a subwoofer. I'd post a link, but I can't. If you google it, I am sure you will see it.
I now want to upgrade something, and I think the smartest would be to upgrade either the front 3 speakers or the sub. Please let me know what you think would be the best upgrade for the system. I listen to about 50/50 movies and music. Also, I would like to keep this under 500. The budget can move in either way though, not by much.
Thanks for the help.
The LCR set up needs to consist of 2 bookshelf speakers due to room requirements.
Also, the room is about 10H x 15L X 12W. Set up basically like this.
so just buy from amazon at $187
