AVS › AVS Forum › Video Components › Home Theater Computers › Is this enough processing power for my HTPC
post #1 of 7
Here is the list of components for my 1st HTPC build.
Antec NSK 2480 Case with 380 Watt Power Supply
ASRock H67M-GE Motherboard
Intel G620 Processor
4GB 1333 memory
Ceton Infinitv 4 Tuner Card
Windows 7
Western Digital Green 2TB Hard Drive
OCZ Vertex 64GB SSD (boot drive)
Blu-ray drive
I am going to use this to record from FIOS TV with the Ceton card, and play blu-ray movies. I also plan on using 2 Xbox360s as media extenders as well as the main TV.
Is this enough power or should I maybe plan on a separate video and sound card to off load the i3 of some duties?
post #2 of 7
Originally Posted by al210 View Post
Intel i3 G620 Processor
i3 2100
-or-
Pentium G620
Which is it, sir/ma'am?
post #3 of 7
Originally Posted by UrbanSmooth View Post
i3 2100
-or-
Pentium G620
Whoops ! G620
post #4 of 7
Whoops ! G620
Is koo, brah.
I'm using the same processor in my build, I'll let you know about performance when it's all done.
post #5 of 7
Anyone else have a similar setup with the 4 tuner card.
I am a little concerned about performance when it will be recording on three tuners while watching the forth. Do you need hyper threading to help? I don't think the G620 has hyper threading.
post #6 of 7
Ceton recommends "2.0 GHz or faster CPU minimum, either 32 bit (x86) or 64 bit (x64) - 2.7 GHz or faster dual-core CPU is recommended"
The 620 dual is at 2.6GHZ, the G840 Sandy Bridge is at 2.8GHz... so according to Ceton you definitely meet the min processor requirements and are just shy of the recommended.
I see very little load from recording ATSC HDTV as the tuner is just taking the data stream and recording it to disk. My peak load is recording a show, watching another show, and comskip processing a third show. It still works, it is just that the GUI becomes sluggish...
post #7 of 7
I'm using an E3400 with the Ceton and it barely breaks a sweat. That SB chip wipes the floor with my CPU so it won't have any problem whatsoever.
