Ok, so I tried ClownBD. Aborted almost immediately. Here is the log:
eac3to v3.24
command line: "D:\\Clown_BD_v0.79\\eac3to\\eac3to.exe" "G:\\HDDVD\\BladeRunnerFC" 1) 2: "D:\\Clown_BD_v0.79\\Temp\\Chapters_2.txt" 3: "D:\\Clown_BD_v0.79\\Temp\\Video_3.*" 4: "D:\\Clown_BD_v0.79\\Temp\\Audio_4_English.WAV" 5: "D:\\Clown_BD_v0.79\\Temp\\Audio_5_English.THD+AC3" 10: "D:\\Clown_BD_v0.79\\Temp\\Subtitles_10_English.sup" -progressnumbers -LOG="D:\\Clown_BD_v0.79\\Temp\\LOGS\\eac3to_PASS3_LOG.LOG"
EVO, 1 video track, 6 audio tracks, 10 subtitle tracks, 1:57:36
1: Joined EVO file
2: Chapters, 37 chapters with names
3: VC-1, 1080p24 /1.001 (16:9) with pulldown flags
4: E-AC3, English, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB, -5ms
5: TrueHD, English, 5.1 channels, 48kHz, dialnorm: -27dB
6: E-AC3, French, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB, -5ms
7: E-AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB, -21ms
"Commentary #1"
8: E-AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB, -21ms
"Commentary #2"
9: E-AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB, -21ms
"Commentary #3"
10: Subtitle (DVD), English, "SDH"
11: Subtitle (DVD), French
12: Subtitle (DVD), Spanish
13: Subtitle (DVD), Japanese
14: Subtitle (DVD), Chinese, "Chinese"
15: Subtitle (DVD), Korean
16: Subtitle (DVD), Portuguese
17: Subtitle (DVD), Japanese, "Commentary #1"
18: Subtitle (DVD), Japanese, "Commentary #3"
19: Subtitle (DVD), Japanese, "Commentary #2"
Creating file "D:\\Clown_BD_v0.79\\Temp\\Chapters_2.txt"...
[a04] The Nero decoder doesn't seem to work, will use libav instead.
[v03] Extracting video track number 3...
[v03] Writing new framerate "24fps /1.001" to bitstream.
[v03] Removing VC-1 pulldown...
[a05] Extracting audio track number 5...
[a04] Extracting audio track number 4...
[a05] Removing TrueHD dialog normalization...
[a04] Removing E-AC3 dialog normalization...
[a04] Decoding with libav/ffmpeg...
[a05] Decoding with libav/ffmpeg...
[a04] Remapping channels...
[a05] Encoding AC3 <640kbps> with libAften...
[a04] Applying RAW/PCM delay...
[a04] Reducing depth from 64 to 24 bits...
[a04] Writing WAV...
[a04] Creating file "D:\\Clown_BD_v0.79\\Temp\\Audio_4_English.WAV"...
[a05] Creating file "D:\\Clown_BD_v0.79\\Temp\\Audio_5_English.THD+AC3"...
[a05] This track is not clean (2).
[a05] [libav] Invalid channel 6 specified as output from matrix
[a05] The libav decoder reported error -1 while decoding.
Aborted at file position 5242880.
