Originally Posted by skeetergmania
I just bought the KDL-46HX820 from TigerDirect as well and had it delivered a few days ago. I was a bit worried with their no refunds policy on this closeout model. But I felt that I was missing some picture quality with the LG LM6700 I had. In any case, the whole buying experience was actually very positive.
My TV came with the top double taped as well. I opened up the TV though and I'm 99% sure it's a brand new TV. The build date is Feb 2012. Everything looked new, but there were a couple scratches on the UNDER SIDE of the TV stand. Is that what you're talking about?
I did see some flashlighting from the bottom left and right corners and a bit of clouding to the bottom left, but these were pretty minor compared to the LG. After I turned down the backlight to 4 (and LED local dimming is set to standard), these seemed to disappear.
I haven't noticed any creases or dead pixels from my standard viewing distance (10 feet), but I haven't examined the TV under a microscope yet.
I'm not sure why you wouldn't use HDMI to hook up a Bluray player. But you should.
Overall very pleased with my purchase from TigerDirect, and the TV is amazing! Trust me, I nitpicked the LG to death and it was a very good TV as well. I'm very pleased with the HD picture quality, the looks, and features for the most part, although the LG supported more video formats over DLNA and was easier to navigate through the menus.
Your reply has been very helpful! Thanks
My tv is also Feb 2012 and yes, I was talking about the underside of the stand as well. I was not using HDMI because I did not have the cable. Got 1 over the weekend and connected the cable box to tv using that. Looks good except for the problems I mentioned in the above post. It must be calibration issue or I am just not used to leds but I feel the picture is a bit hazy/out of focus. The picture looks pretty good with lights turned off and from around 8-10 feet.
What settings do you use for watching normal television? Thanks once again for replying
