AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sony HX820 Owner's Thread (46HX820, 55HX820)
Official Sony HX820 Owner's Thread (46HX820, 55HX820) - Page 10
post #271 of 2584
Folks I just got my HX820 55 delivered few days back and so far I am in awe with the pic quality..., have watched Dark knight, Avatar and Megamind. However when I connected my ps3 today....I noticed a bright patch of light at the bottom left hand corner (enclosed pic). I am not sure if this is defective TV or just needs some calibaration. Please do share your views/ccomments/suggestions
post #272 of 2584
I don't see the spot. The XMB is naturally a little uneven. Try a different theme. Maybe a dark background and take a pic?
post #273 of 2584
Hello. Congrats on the new TV
I can't really see the "bright spot" in this pic. But I also agree with Aguayonex LEDs are "naturally a little uneven."
Also, when I view the PS3 home screen on my HX820 I always see uneven brightness and shades of color as the PS3 "wave" graphic crosses the screen.
However, if it really looks odd to you, perhaps try Adjusting TV backlight and/or brightness lower.
BTW are you using High Speed HDMI cable?
post #274 of 2584
Yes, connected via Monster HDMI cable ...says it supports 10.2 gbps+ speed. btw, thanks for the quick responses....will take a pic with different image and see if the spot is similar.
post #275 of 2584
I got this TV in last night from UPS (Last night is about 9:30 PM) set it up watched a few minutes of it, looked nicely colored and deep blacks. Do I need to set it up (calibrate) it anymore than what was already setup by Sony? Is there a difference in PQ if I do calibrate it? thanks. BTW: Have original PS3 (HDMI), DirecTV (HDMI), 360 Slim (HDMI), and Nintendo Wii (A/V). all plugged in.
Oh and one other question...I think I currently have a HDMI cable version 1.3 from my DTV to my TV but my TV can detect the 3D signal from my DTV box and my DTV box can detect 3D from my TV, do I need to get HDMI 1.4 for good quality?
thanks.
post #276 of 2584
thanks.
Kuzco--I think you are going to have a lot of fun with this TV and all those devices you've got hooked up
Here's a reference for the HDMI cables on wiki:
http://en.wikipedia.org/wiki/HDMI Scroll down to the HDMI version chart--you will see according to Wiki author 1.4 is the only cable that supports ARC ( Audio Return Channel). So if you ever hook up an external A/V receiver or sound bar, "The Audio Return Channel in HDMI 1.4 enables a TV, via a single HDMI cable, to send audio data “upstream” to an A/V receiver or surround audio controller, increasing user flexibility and eliminating the need for any separate S/PDIF audio connection." Here's a link to illustrate ARC capability http://www.hdmi.org/manufacturer/hdmi_1_4/arc.aspx
As far as all your other components, HDMI 1.3 a, b, or c should be okay for 3D and everything else. Seems like you are all set there with the cables you are already using
BTW--the inexpensive HDMI cables work just a well as those other expensive HDMI cables--so don't let any marketing or sales people convince you otherwise. As long as they are high-speed 1.3 a, b or c, or 1.4 that's all that really matters.
post #277 of 2584
I've been looking for Vudu so I can watch 3D movies on my TV, doesn't seem like its on it, but, I'm not entirely sure, so I am curious if anyone knows if Vudu is on it, and if so, where would I find it? thanks.
post #278 of 2584
Vudu was not included on the HX820. However,you can get it on the PS3--you just have to download the app to the PS3 from the PS3 network.
Qriocity, Sony's streaming video app (included on the HX820) has both free 3D content and 3D movies for rent. Also check out Sony's 3D experience ( several free 3D clips) on the video app menu as well. Enjoy!
post #279 of 2584
Just picked up the new Sony 3D kit with the Chronicles of Narnia and 2 pairs of their newest glasses.
I have to say, these things are down right rubbish. I have never put something so uncomfortable on my head. I am so thankful I have a pair of the older BR100's or I would be done with 3D. They are so completely narrow on the back of my head even my wife (smaller person with small head) can't wear them without getting visible dents in her scalp.
I am shocked that Sony can put these cheap flimsy pieces of crap out for sale when Samsung is offering like 4 ultra comfort choices.
post #280 of 2584
Hey Guys....Has anyone hooked this TV up to your PC. Is their any way to do this without
a D-sub 15 cable. Any help would be appreciated...
post #281 of 2584
Just found a stuck/dead pixel. It appears to be red and stuck, but looks sort of black'ish on other other colors.
post #282 of 2584
It depends on which connections your PC has. You can connect it to the TV via HDMI or use a DVI to HDMI adapter if your PC supports one of those.
post #283 of 2584
So, I don't have to follow the directions that the imanual gives? I can connect it to any input?
post #284 of 2584
I was able to get rid of most of it with some pressure, however I can see a faint mark only at certain angles (not dead-on.)
I've tried tapping it, thinking it was dust but I have no idea. In any case, you can't see it unless your 2-3 feet from the screen and REALLY looking for it. I mean, I have a hard time trying to find it.
post #285 of 2584
I have had this tv (55) for about 2 months now. Pretty happy with it. I have noticed some unevenness with the brightness as you go across the screen (kinda like a fog in some spots). Not terribly noticeable and I have spent no time at all tweaking the settings, so I'm not too concerned.
However, last night I fired you ModNation Races on the ps3. When driving around in a constant circle, I see the scenery 'stutter' every now and then. I really haven't noticed this before. But now it's all I can focus on. I tried the game on a 46" sony I have and it's as smooth as silk. However, there is one difference-- the 46" has a ps3 slim hooked up to it and my hx820 (55) has the 60gb original launch model.
Anyone know if there is a difference between the slim and fat models of the ps3? Differences that any affect speed or screen rendering?
I guess my next step is to swap the ps3s and see if the slim 'stutters' on the 820. Just thought I would ask before I went to that trouble (tearing these apart out of the entertainment centers is not easy).
post #286 of 2584
Sony's official answer is that there is no difference in specs. However, reality is that the fat models are older, have been used more and thus have more dust in them so they tend to be a little buggier. They also use a larger, hotter and less efficient processor. So I'm not at all surprised by what you noticed. I'm a huge gamer and have noticed that, although this TV looks awesome, it does require so extra work if you really want to remove input lag.
ModNation is a great game BTW! Really wish I didn't trade my copy in a few months ago.
post #287 of 2584
.... I'm a huge gamer and have noticed that, although this TV looks awesome, it does require so extra work if you really want to remove input lag.
Any suggestions? I just selected Game Scene and saw that all the extra processing stuff was turned off. I thought that was the best I could do for gaming.
post #288 of 2584
Just bought a 5.1 Sony speaker system SA-vs310 I think it's called. With two tall front speakers. Had to buy a seperate receiver tho since it didn't come with any... Sony Str-dh820. And so far LOVING it. Btw..got the speaker system for 200 bucks in bb while amazon had it for 350. So great deal there. But got the receiver from amazon..a 70 dollar save. Overall a 500 dollar purchase.
P.s. I ain't no audiophile and I am glad for that. Will post some pics tomorrow morning
post #289 of 2584
So I did that. No difference. So it's not the ps3 fat vs slim. However, I did look close on the 46". It does seem that there is a little jerking. Wondering if the size difference makes it more noticeable.
post #290 of 2584
It does turn everything off, but the picture looks like crap in my opinion.
post #291 of 2584
So what did you turn on to improve the picture but make sure lag didn't increase? I'm a huge gamer as well and would love to get my games looking their best. Currently I play a lot of COD:BO and Borderlands so I cover a wide range of graphics, necessary input time, etc.
post #292 of 2584
Wow! You are on your way to a very nice surround sound environment to go along with that fantastic TV. I think you can go beyond 7.1 with STR-DH820--if you include a second sub-woofer ( one SW in front, one SW in back).
post #293 of 2584
I just go with the same settings I use elsewhere. Honestly, the lag has not affected my KDR at all. But I'm pretty mediocre (1.0 KDR.)
post #294 of 2584
Like your latest settings on page 9 for example?
Not sure if I have just been playing worse lately or if there was a tiny increase in lag between my Samsung 32LNA550 and my HX820 but my KDR has definitely been going down as of late (3.4 to 3.35). So I will definitely have to tread lightly when adding in the processing options. Which one do you think made the most difference in PQ once enabled?
post #295 of 2584
Yes, the ones on page 9 are my settings. Except I have switched to "clear" vs. "standard" under Motionflow.
They all impacted the PQ (improved it), which is why I keep them on. Plus, my primary source of TV/Movie is Hulu Plus, Netflix and Vudu. Both my Xbox 360 and PS3 hook directly into my receiver via HDMI and the reciever sends one HDMI to the TV. I switch back and forth on the receiver between Xbox and PS3 depending on what I'm doing. So that means the TV really only has one active input and the idea of fiddling around with my TV settings every time I watch Netflix, or play CoD, or watch a Bluray annoys me so I went with one all around "best picture" setting and stick with it. To be honest, the lag really doesn't impact anything. I still have good games and bad games and don't feel anything at all. I think if someone really cared about lag and gaming they would have their concern better spent on making sure they have a super high speed internet connect and they keep in wired, not wireless. That makes more of a difference than anything IMO.
But...., if you really want to limit the lag, turn off the MotionFlow and CineMotion. These two will account for most of the lag you'll experience in gaming. The subtle adjustments (detail enhancement, black corrector, clear white, etc.) won't really have any impact whatsoever. Of course, the downside is that believe it or not, they really do help smooth out the picture which in video games includes A LOT of fast movement.
post #296 of 2584
The new ht system
the surround speakers...
post #297 of 2584
The new ht system
Looking good!
This weekend I had the opportunity to watch an epic 2 disk blu-ray movie Director John Woo's "Red Cliff " (Mandarin: DTS-HD Master Audio 5.1 w/ English subtitles). This movie looks and sounds GREAT--maybe something to try on your new entertainment center.
http://www.amazon.com/Red-Cliff-Inte...4741146&sr=8-2
post #298 of 2584
lbj2, thanks. will check it out. already got master and commander, tron and the island to check out the sound in the next 2 days. heard great stuffs about the sound of these movies in avs. next will be red cliff for sure
post #299 of 2584
FYI: New HX820 firmware update PKG3.407AAA. If you haven't done so already--you might want to check for your update. I don't know what the update includes as they haven't posted the details on the Sony support site yet. They still list the old firmware version at http://esupport.sony.com/US/perl/swu...ab=downloadTab
From past experience I haven't seen Sony post firmware updates details for at least a couple of weeks after they release a new version.
post #300 of 2584
It seems like the last several updates have just been IPTV features, not really panel performance.
Since mine is set to auto update, I presume it has already updated or will since I leave it in standby mode when not in use. ?
