AVS › AVS Forum › Audio › Speakers › Is this speaker wire good for my new speakers?
Is this speaker wire good for my new speakers? - Page 2
post #31 of 59
I bought some there and it was green within a few months. It oxidized really badly.
Didn't take any science classes eh?
Copper, regardless of its origin, will react with other elements in the environment. Believe it or not, this surface corrosion doesn't have any effect on the transmission of current.
Not knowing the difference between an oxide, sulphate or chloride, doesn't instill much confidence in your determination.
post #32 of 59
Is the GE wire 100% copper or...?
post #33 of 59
don't be cheap...is this one speaker? use not less than 14ga good quailty wire not the home depot type ...you will hear the difference hear is a link to a question that I did on this issue on Amazon http://www.amazon.com/Monster-100-Feet-Speaker-Cable/product-reviews/B00006345D/ref=cm_cr_pr_top_recent?ie=UTF8&showViewpoints=0&sortBy=bySubmissionDateDescending
post #34 of 59
Buy speaker wire with opaque insulation. You'll never see or hear a difference.
post #35 of 59
Wow, the dead truly do rise smile.gif I thought I was reading something current. The OP has probably experimented with all kinds of cable by now.
I got my first cable from Lowe's, roll of 100ft 14awg, never turned green, RCA brand, really good stuff. Eventually went with Monoprice in wall for a nice little diy project, cable pants, techflex, heat shrink, banana plugs, so when friends come over and see my cable runs and say wow, how much did that cost, I tell them, oh about 500 per foot biggrin.gif
post #36 of 59
post #37 of 59
Actually I bought some 12AWG monoprice speaker wire and installed 5 lengths behind some walls. One of them had an open wire. It was more of a no copper problem, than a bad copper problem. Manufacturing defect I guess. If you buy this stuff dont forget to test for continuity and resistance before installing. I just buy the Belden stuff now.
post #38 of 59
It's still oxidation genius. Oxidation is a reaction with oxygen.
http://www.corrosionist.com/why_does_copper_turn_green.htm
post #39 of 59
post #40 of 59
"Initially, bare Cu metal atoms react with air to form the pink oxide, cuprite, Cu2O, which has Cu+1 cations. This gradually oxidizes further to the black oxide, tenorite, CuO, with Cu+2 ions. The black sulfide CuS also sometimes forms. In the presence of moisture, the blackish layer slowly reacts with sulfur dioxide and carbon dioxide from the air to eventually form the patina"
post #41 of 59
Technically, oxidation involves the loss of electrons and doesn't necessarily require oxygen.
In the case of the green coloration, it's a reaction between the copper and the sheathing material which is typically PVC. It's caused because over time and exposure to environmental variables such as temperature, the PVC degrades to form hydrogen chloride as one of the decomposition by-products. The reaction product, copper chloride, is green. Depending upon how the PVC is stabilized, the wire may never turn green or it may happen rapidly.
post #42 of 59
LOL.
Copper forms a brownish red and a black oxide.
Sulphates are blue and chlorides are green.
Why don't you take an "introduction to science" class before embarrassing yourself again, genius.
post #43 of 59
Originally Posted by Geoff4RFC View Post
Cracked me up too.... try to understand what your linking to...you just proved me right, while making yourself look pretty stupid.
post #44 of 59
The Process still starts with a reaction to oxygen and several steps it turns green, but you still need oxygen to start it off. Chu Gai, oxidation is both, a reaction with oxygen or the removal of electrons.
I'm so glad you are a chemistry guru Sam, perhaps you had better go back to basic chemistry class. I've had chemistry all the way through bio and pchem, I think I have a handle on the basics.
http://www.tech-faq.com/what-causes-copper-to-turn-green.html
http://www.answers.com/topic/oxidation
post #45 of 59
Playing the devil's advocate:
If you have 25' of speaker wire that green in the middle, how does oxygen creep into the jacket?
Most probable is that the clear insulation (typically PVC) is the culprit that is reacting (chlorides) with the copper
post #46 of 59
I had PChem too as well Quantum, and several graduate level courses. About 10 years ago I had some green wire run through an XRF which besides copper detected significant levels of Chlorine. There was only one source of that which was the PVC insulation. I'm not going to postulate the mechanism for the formation of copper chlorides but that was what was ultimately formed. It's pretty much a surface phenomena that only goes down a few microns. If one wants to avoid it, use wire with a different insulation. Liberty I think makes some with PE. I am though of the opinion that HD stuff is driven by low cost. FWIW, I have some SoundKing wire that's not green.
post #47 of 59
post #48 of 59
Okay, ignoring the chemistry for a minute (and yes, inorganic, organic chem, Biochem and three semester of teaching inorganic, but not wanting to turn AVS into a chemsitry forum)...
Has ANYONE ever shown a single measurement showing that expensive, non defective speaker wires has better "signal" than inexpensive, non defective speaker wire? I have seen claims by Monster and others, but I have never seen a single experiment that would support those claims
post #49 of 59
No.... that's how they sell expensive speaker wires. There's nothing Mon$ter or others want (or can) prove. That's all they are.... "claims". The rest is up to the consumer's pocketbook.
post #50 of 59
Yes, the wire will measure better, but the improvements are well outside of the audible range. So it's basically bogus.
Edited by flyng_fool - 6/27/12 at 12:36pm
post #51 of 59
Yes that's true chlorine will do it. I was referring to the natural green patina process. And yes, I know it will not make any difference in sound. But wire isn't supposed to turn green inside it's jacket. I prefer the products I purchase to be without any glaring defects.
post #52 of 59
With sufficiently sensitive instrumentation, cables can be "fingerprinted." Some will pass
a better reproduction of their input than others. This is easily verified.
However, who cares? We don't need "perfect" cables to get the best sound that can
possibly be produced by our systems; we need cables which are "good enough."
I don't need a speedometer in my car which is accurate to 0.01 MPH. Does an
expensive cable sound better than my cheap one? Does my cheap one sound
better? Is it possible that nobody can tell the difference in an actual test?
Advertising and marketing claims by manufacturers, at least those made in the
U.S., are valueless and have no meaning. Does it sound better to you or me?
Nothing else matters. Except I like a good-looking cable better.
post #53 of 59
I was going to stay out of this... Sam, you may know your chemistry but you don't have to be condescending at every turn.
As for Didn't take any science classes eh?, that is actually a logic mistake. Chemistry is a science but not all science is chemistry; I may be a scientist and still know nothing of chemistry.
post #54 of 59
Measure all you like, a 25' 14AWG lamp cord @ $.50 per foot will sound no different than 25' of a 14AWG "boutique" speaker wire @ $20 per foot.
If one desires to spend money unnecessarily to have speaker wire that looks goods, that a personal preference.
It's like I don't like seeing a pine tree shaped air freshener hanging from my car mirror. I prefer a "clip on" that attaches on the dash. tongue.gif
post #55 of 59
I don't measure nothing. I haven't measured anything since I took EE 201 in Spring,
1978. The differences are areal and may be important to EE's and physicists. The
real difference for me is ...
I like Monoprice's zip cord, myself.
That's why I invest in TechFlex covering and little rubber cable pants. It looks
better, ergo it sounds better.
How gauche!
post #56 of 59
Originally Posted by Hamilcar Barca View Post
Some will pass a better reproduction of their input than others.
Not within the audio bandwidth. That's the stuff which is in such fine print that even a gnat can't read it.
We're the ones who know enough not to fall for the cable mountebank's nonsense. It's those who lack an understanding of how speaker cables work, and all cables for that matter, who fall for their shenanigans.
post #57 of 59
That's why I invest in TechFlex covering and little rubber cable pants. It looks better, ergo it sounds better.
Great investment I guess.... but, if it looks better, that doesn't equate to sounding better. FWIW, over 35 years, I have never had anyone ask to look at my speaker wires. They take more interest what's in my fridge. wink.gif
post #58 of 59
That was my bad attempt at parodying the "if it costs more it must be
better" myth. Sorry.
post #59 of 59
Just going by another post also.... sorry, didn't know how to interpret your parody.
(You better work on that. wink.gif )
  Back to Forum: Speakers
