AVS › AVS Forum › Video Components › Home Theater Computers › Extender question....
post #1 of 22
Hi fellas, i'm new to this WMC thing so bare with me. I'm looking to setup my pc as a dvr for the tv in my living room. Problem is, i don't want this eye sore of a desktop in my living room.
So, if i buy one of these: http://www.amazon.com/Genuine-Dell-M.../dp/B003QQOHZ4
Will i still be able to use my Pc normally (web browsing,burning cd's, etc) with WMC running in the background, from it to the tv upstairs ? (I'll prob run an HDMI cable as well) Or do you know of something similar i can purchase that'll do the same task ?
Thanks in advance....
post #2 of 22
What you want is a real "extender". And Xbox 360 is the current best choice for this purpose; you run media center on any PC on your network (yes, you can leave it minimized) and the Xbox connects that PC and gives you the standard media center interface (exactly what you see on your PC when you run media center). You will just need a network cable to connect them both.
post #3 of 22
If i ran HDMI to the Xbox, will i be able to watch in HD ? Also, can i still use my pc while WMC is running on the tv in the background ?
post #4 of 22
Bump
post #5 of 22
Yes to both.
CFC
post #6 of 22
Originally Posted by CFC View Post
Yes to both.
CFC
How would i do that ? Software ?
post #7 of 22
MCE Extender is built-in Xbox 360.
You don't actually need to have MCE running at the same time you use an extender. The computer itself needs to be running though.
CFC
post #8 of 22
CFC
Appreciate u taking the time to help out. But i didn't want to stream it to my Tv, i wanted to hard wire it to my Tv via HDMI to view in HD, but i want to use my PC @ the same time. How exactly would i do that ?
Sorry for the noobiness...
post #9 of 22
The way extenders work is that they are a small box that connects via HDMI or Component (for HD) or composite/S-video (for SD - and RGB SCART for SD in Europe) and are connected to a PC running Windows via a network connection. The Windows version running on the PC needs to have Media Center (Windows 7 Home Premium for example)
This network connection between the extender and the PC can be via WiFi (not always that good for HD) or cabled ethernet. If using cabled Ethernet this can be either using a run of Cat5-type cable or in association with something like Moca or Homplug if you can't run Cat 5 for the entire distance between the PC and the Extender.
The Extender can then access any Media Center compatible tuners configured within Media Center on the PC, access any Recorded TV in that PC's Recorded TV library etc. The PC itself needs to be switched on and running Windows (and have a working Windows Media Center configuration) - but the PC doesn't actually need to be running the Windows Media Center application for the extender to work (this happens in the background)
Similar TV recordings will still happen if Media Center isn't running as they happen in the background as well.
The term "streaming" is used to describe playing live or recorded content on a device that doesn't have local storage of that media and is instead accessing it via a network (whatever the network connection maybe)
post #10 of 22
Well... The answer to your question is:
Get a video card that has dual outputs (and at least one HDMI). An ATI 54XX series would be perfect.
Then, either get a long HDMI cable (<50'), or get a HDMI over cat 5 extender (you'll need dual cat 5 for most of the ones that I've ever seen).
Next, get an IR repeater and run the IR (remote control) signal back from the TV to the computer.
Finally, run 7MC on the PC and put it on the "2nd monitor" (that would be your TV).
However, that said... I don't think this is going to work the way you want it to. It's very easy for media center to lose focus, and also very strange to use a computer with "dual monitors" that have the monitors in different rooms. It's going to be kind of difficult to deal with (things opening on the wrong screen, for example).
For what you'll spend to extend the HDMI cable to the other room, you might be able to buy a small PC to put there. If you have to go more than 50', you're definitely going to spend more (the HDMI extenders are expensive), you'd be better buying another PC (or an XB360).
I've seen setups like this, but never with the TV so far away (typically in the same room, makes it much easier to deal with issues when they crop up; and they will).
post #11 of 22
Ok, here's my setup. I already have a video card with dual DVI's & HDMI adapters in the basement. I can run anything to the TV upstairs with no problem being that it's only less than a 20 ft. run. I also already have my router in my living room entertainment center. Maybe i should've explained this earlier..... My bad
post #12 of 22
Wow. what an idiot. Just did some more searching, & it seems like i can view the live HD content via Xbox 360 extender hard wired to the router via Ethernet ? Am i right ?
post #13 of 22
Correct, as long as your computer is also on the network, and is on.
post #14 of 22
NICE !! Can't wait to get this up & running. How is the quality of HD ? Any noticeable difference ?
post #15 of 22
It should be good. What are you going to be using to get the data, TV tuner, cable card?
post #16 of 22
Yep, i was looking @ that Ceton InfiniTV 4 Quad-tuner Card....
post #17 of 22
Yep - the XBox 360 will also work as a Media Center Extender (and has the bonus of supporting H264 as well as MPEG2 Live/Recorded TV for those of us who get HD in H264 not MPEG2!)
For Live/Recorded TV you should see no major quality issues. If you want to stream other video files then things get a bit more complex - but for Live/Recorded TV it's great. You also have the bonus of there being a DVD player in it!
post #18 of 22
Awesome, thanks. Now if i can only come up with the $$ to buy all these toys...
post #19 of 22
Does it matter if it's a 4GB or 250GB xbox ? All the DVR'd shows can get saved to the PC, right ?
post #20 of 22
Doesn't matter a bit. All is done through the PC.
Enjoy it.
CFC
post #21 of 22
Enjoy it.
CFC
I'm gonna enjoy giving back the ISP's DVR a lot more....
post #22 of 22
What remote control works best with an Xbox extender that can also be programmed to my tv ?
