Mayer,
How are things with the Sony, now that you are using the anamorphic lens? Still planning on using it for 2D?
Can you tell me how far you would expect the lens to stick out from the front of the Barco projector. I will be using the 1.38 DC4K (1.45-2.13)
Order number R9855943 lens.
I can't get any info on how far it will stick out! I know the projector is 1129mm deep but i don't know how much more to add for the lens??
I hoping either you or Peter would know!
Chris
Chris
